I have a 1996 Camry LE 4 dr. The OEM power antenna works fine with the ignition turned to on. Once the car is started and running the power antenna will not work. If you turn the engine off and leave the key on it will work again fine. I installed a new mast but the problem still happens. The car has the factory radio and antenna and no wires have ever been messed with. Thanks with any help with this.
Mike
Panama City, FL
Mike
Panama City, FL
