No.Ukrainian102 said:The torque peak for the 7A-FE if I remember correctly is ~2,400 rpm. Should be close to that on the 4-AF. Maybe that's why.
That sounds way offUkrainian102 said:The torque peak for the 7A-FE if I remember correctly is ~2,400 rpm. Should be close to that on the 4-AF. Maybe that's why.
The reason for the power/torque decrease on the 7AFE is emissions related... and they did decrease a bit... although 134 ftlbs is an exaggerated number (110-115 ft lbs is about right)... and the max torque does peak in the 2500-2800 rpms range, depending on who you're asking.Chris Corolla S said:Cool I have a link that says stuff too, who knows what it is![]()
This has an AE102 4a-fe with a TQ Peak at 3,000 RPMs:
http://autos.msn.com/research/vip/spec_engines.aspx?modelid=2785&trimid=-1&src=VIP&tab=2&sub=1
This one has the 7a-fe at 134 ft-lbs of Tq![]()
http://autos.msn.com/research/vip/Spec_Glance.aspx?modelid=2758&trimid=-1&src=VIP&tab=2&sub=0
But this one supports the 2,800 RPM claim for the 7a-fe:
http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/GasolineEngines.html#A-series
To get back on topic the above link also shows that the 4a-f has peak HP at 6,000 RPMS (90HP @ 6,000, 95lb-ft @3,600) so it should be screaming at 5,000 RPMs not slowing down.
