1 - 9 of 9 Posts
Toyota-Lexus Fanatic
95 Camry LE
Highlander 2001 2.4 Liter:
Will do drain and fill on tranny. 3.5 Qts, T-IV.
Will drain and fill power steering fluid, what to use? Dexron III? Or T-IV?
Thanks in advance.
'06 Seinna XLE AWD, '04 Highlander V6 4WD
Good
Thanks in advance.
Tranny T-IV is the correct amount.
For teh P/S system use Dextron III or BETTER Dextron fluid.
2004 I4 Highlander
2001 Honda Accord
T-IV/3309 isn't much different than Dexron III. Many dealers will use the T-IV in the power steering. I used Mobil 1 in both.
Assuming it's the same as my 04, 3.5 quarts seems right. I drain into a marked container and put back what I take.
95 Camry LE
Discussion Starter · #4 ·
Thanks.
Confirms the info on the amsoil website.
Earlier Highlanders have a 4 speed transaxle, our '04 have a updated 5-speed transaxle. Ibelive they have diff. fluid capacity. Will be in the owners manual for sure.
95 Camry LE
Discussion Starter · #6 ·
2001 so 4 speed. T-IV.
2004 I4 Highlander
2001 Honda Accord
"Earlier Highlanders have a 4 speed transaxle, our '04 have a updated 5-speed transaxle."
All 4cylinder Highlanders right up until 2007 have a 4speed. Only the V6 has a 5speed.
I also want to clarify that the correct power steering fluid for the 2001 is Dexron III or equivalen, not T-IV. Maybe some put T-IV in without a problem, but to my knowledge that's not what the manual recommends.
95 Camry LE
Discussion Starter · #9 ·
Dexron III it is then. My RX330 uses Dexron III.
1 - 9 of 9 Posts
