1 - 7 of 7 Posts
The high pressure line on my 98 SR5 is
very pitted and has started to weep. I called the local toyota dealer for a price and it's in excess of $400! Does anybody know of another source for one of these or anyone with a good used one that they would part with? Also the bracket with the two short rigid lines that connects the rubber tranny cooling lines is starting to leak too. Dealer gets $44 for that, but I'll take a
used one if possible.
Thanks
I believe our local NAPA makes up hydraulic lines also.
What kind of fitting is on that line? is it just a flare type or a double flare? Might be worth investing in a flarer if so and bending up your own.
Discussion Starter · #6 ·
Prefer original
It's a banjo fitting at the pump and a flare when it connects to the steering box. I suppose I could fab the section that runs across the radiator support and have my local hydraulic guy crimp on a new rubber line, but I really want original plug-and-play installation.
Thanks guys
1998 T100 SR5 2WD
Thanks guys
If you want original...yer gonna have to pay. ;):(
1 - 7 of 7 Posts
