1 - 3 of 3 Posts
Does anyone have a picture describing where the power steering pump is located? I can't seem to find out where the leak is coming from.. it's from the driver's side and not the passenger's side (where the power steering reservoir is located).
92 camry 4cyl
Ninja wrench anywhere
I don't have a picture handy, but the pump itself is on the passenger side of the car, quite a bit below the dogbone engine mount and a bit toward the firewall. Just follow the hose from the power steering fluid reservior back toward the firewall -- it'll lead you right to the pump. There are hoses from the pump over to the steering gear housing -- not quite on the driver's side, but moreso than the pump itself. It's a pretty high-pressure system, too, so a leak can spray around a bit.
R&R instructions at http://www.camrystuff.com/manuals/Gen3/sr.pdf .
1 - 3 of 3 Posts
