1 - 6 of 6 Posts
Hi Guys, my first post, I think this is great helping each other out.
Okay so I hear teh growing noise, to find out the fluid level was low last saturday, filled it and then check again and just what I tought was again LOW LEVEL.
This morning I found really really dark fluid falling off from drivers seat tires.......
Can you tell by location what part is leaking or is it just hoses loosend up? :confused:
Common to have the pump or rack leaking before the hoses, but hard to diagnose from here. If it is leaking that fast, it should be relatively easy to find the source. Most shops will stick it up on the rack and give you a diagnosis for free.
Welcome :)
Most likely your power steering rack is leaking throught the boot on the driver side.
If you can access underneath the car. Snip the driver side rack boot and see if fluid starts pouring out.
Or just visually look for damp/wet spots.
1 - 6 of 6 Posts
