Hi,
My 05 Corolla lost it's right rear power window functionality, I took the door panel off and tested all the connections, They all have power and seem fine. dont see any pinched wires off hand.
I took the left rear panel off and removed the switch and tested it on the right side, didnt work. the right switch does work on the left door so that eliminates the switches. I even took the regualtor out of the right rear and connected it to the left rear and the motor went up and down without any problems I also tested it with both switches.. no problems at all.
I left the right regulator in the full up posistion so I could install it and with the window in the closed position. As soon as I plugged the motor connection for the reg in the right door.. it turned the motor on and went back in the default posistion. I was still unable to get the motor to actuate again. I went and retested everything again.. all my connections and swithces and regualtors. all are working except the right rear. and If I have the regulator in the extended posisiton, when I go plug it back in on the right rear it actuates and goes back to the defalut posistion.. This one's got me, anyone have any good tips or electrical tips I can check on .. .I would take it to the dealer, but my 05 has 127184 miles on it already and is waaaaaaaaay out of warranty.. I know... I have a 200 mile round trip commute.....
If anyone has any tips or anything they could offer on this it would be greatly appreciated
Thanks!
Thanks!
