Is the driver’s console window lock on?
The door lock and power window systems share some circuits but are pretty much separate. Check the IG-1 relay, AM-1 and ECU-IG fuse. Both circuits receive power from the ignition switch.
Many times the wiring running between the driver’s door and frame breaks due to the door being constantly opened and closed.
You can remove the drivers side door panel and check for DC power at the console.
