Do the other passenger windows work? Are you sure you didn't accidentally activate the window lock? If I recall, it's basically a ground break. If you did, a few cycles of the switch as it may be oxidized may need to be necessary in order fer it to work again.
Did motor sound like it was straining going down? You can power the motor directly and see if there are any issues with that aspect of it.
