I know this is not to exciting but I was wondering if I need to use toyota red coolant in an oil consuming 2000 motor when doing a flush. or if it even maters .hello again everyone is there any reason not to use prestone antifreeze after a coolant system flush ? thanks.
thanks for the reply! the P.O. had red in it. But its hard to tell how old it is.I can think of two good ones and one vain one:
1) It doesn't meet factory spec for our cooling systems.
2) It has a different chemical property and could lead to the aluminum parts in our cooling system to corrode.
3) It's not as cool looking as the Red stuff...
In all seriousness though, Prestone's Universal may not meet factory specs (borate/silicate free) and could easily gum up the cooling system. NAPA carries the 50/50 mix of red for around $13 per gallon -- not too expensive and about half the cost of Toyota branded coolant.
Always best to use the recommended coolant.Stay with the Red.
Stay with the Red.
Is there a way to drain the block. The parts store said the system only holds 6 quarts, in order to get to the proper 50-50 arent you going to have to drain the block. Thanks.
In fact there is. These engines have a drain valve and spigot on the exhaust side of the block on the driver's side.Stay with the Red.
From the driver side above the engine:
Looking straight down from the top of the engine, the drain valve and spigot are at the bottom of the water jacket on the engine block. Attach a section of rubber tubing and aim it at a catch basin. Use a wrench to loosen the drain bolt.
lol, your edit. You cant say c**k! LOL ! Thanks again !In fact there is. These engines have a drain valve and spigot on the exhaust side of the block on the driver's side.
Oh yeah I knew what you were talking about. Its the same as a pet c**k ,that isn't a pet, its a valve, lol. seriously though do you get to the D.C. from the top or bottom of the car?You guys are a riot! lol. That's what it's actually called though! Definition is basically a drain tap used to drain water, steam or air from a sealed system. Which is exactly what the water jacket in the engine block is.
Oh well... so much for being technical.
I like my ramps for a job like this. thanks again for the info and PICS!You can get to it from both sides. Probably easier to get to it from underneath if you have a good set of jack stands.
So, then, a vacuum-powered attachment for sealed systems would be called a...... oh, nevermind.You guys are a riot! lol. That's what it's actually called though! Definition is basically a drain tap used to drain water, steam or air from a sealed system. Which is exactly what the water jacket in the engine block is.
:lol: sometimes it helps to have a sence of humor when dealing with Gen 8 rollas :facepalm: can I still say blow by?So, then, a vacuum-powered attachment for sealed systems would be called a...... oh, nevermind.
Or ramps. Ramps work well too.I like my ramps for a job like this. thanks again for the info and PICS!
Hey, why's your hand on your... wait, we're allowed to say head, right? What else do you call the tool end of a bolt? Aww, crap, "tool" and "bolt" are ok, right?:lol: sometimes it helps to have a sence of humor when dealing with Gen 8 rollas :facepalm: can I still say blow by?
