1 - 5 of 5 Posts
'89 Celica ST162 JDM
Hey there,
I think my thread is most appropriate in this category.
I was given for free a (2006-ish I think) front fog light switch from a Prius.
Currently I have installed fog lights on my 1989 Celica (ST162) and i just have this universal ugly switch that is lit while "ON" (3 pin switch).
--> I would like to put instead the Prius switch that has a background illumination (to be seen during the night) and that has a light indicator when ON.
Only thread I could find about this is in Russian and wasn't clear enough for me :
https://www.drive2.ru/l/2305425/
I'm struggling in the process of connecting the wires... didn't find any other relevant threads for my issue.
See pics below - I put some numbers to make it more clear with the wiring.
Any help would be appreciated, especially if some of you are familiar with this switch.
EDIT: This switch seems electronic and linked to the ECU? (same position for ON-OFF, no "clic" with 2 different positions?) A mechanical switch would be the only option? Switch number is Toyota 156753.
Discussion Starter #2
From what I gathered until now:
1- (+) goes to the relay
2- some permanent/after contact (+)
3- ?
4- ?
5- ?
6- Ground
7- Ground for the illumination
8- (+) for the illumination (comes for another illumniated switch)
Have you... looked at a wiring diagram? That will tell you all the answers.
1 - 5 of 5 Posts
