1 - 15 of 15 Posts
I am pretty impressed with the prius.
I just rented one last weekend for my drive to LA (from SF). I raked in about 1,000 miles and spend $66 on gas. This includes filling it up to return to the car rental.
· TN Member
Prius
Discussion Starter · #3 ·
Glad your experience went well. just came down the mountain (have Nokian WRs on). They closed the roads for 2 hours cause they couldn't clear it fast enough and stupid people in RWD cars were bumping into each other and concrete barriers so they shut the road down.
· Ex-Master Diagnostic tech
15 Ram 1500 Diesel
It does not make sense for me. I never liked it or the other hybrids. I would much rather see Toyota produce a CRD Corolla stick with legroom for a non japanese person. And I don't want to hear that I just do not understand them. I am Prius certified in both gen 1 and 2 and camry/highlander certified. It is an engineering excersize which allows Toyota to say, look we are green. Nonsense. Bunnies and trees do not come out of ANY tailpipe.
Unfortunately the neat diesels that europe gets we do not. We get the Prius.
Oh btw I see 40+ mpg with my VW diesel. Unfortunately the rest of that car is a POS.
· Tacoma Rocks
Nothing like the opinion of someone with plenty of knowledge...would u care to explain more why u dislike the car, why is a POS?
· TN Member
Prius
Discussion Starter · #7 ·
Sounds good. I get up to 60mpg in the hilly PNW and high 40s in the winter. Current lifetime mpg is 49mpg after 74,000kms.
Also you gotta look at emissions. Only the Civic Hybrid beats it (Tier 2 Bin 2. Prius is Tier 2 Bin 3).
Even the Camry/Highlander are Tier 2 Bin 3 which beats pretty much 99% of the cars out there. Not bad for a 2,000kg SUV.
Also the diesels in Europe that we all hear about and get fantastic mileage are great except people tend to forget they're 1 litre to 1.4 litre diesels in cars smaller than a Yaris and take 15-20 secs to 60. (See the 05-07 fortwo cdi for example).
It's always a case of the "grass is greener on the other side". We don't get it, we want it. It comes over here, we complain about its shortcomings which we never considered because we refused to learn about them.
· Radio, this is Unit 91...
1993 Camry LE AT
Well said! I applaud Toyota, not only did they give us a semi-mainstream hybrid sedan, but they even made a 2nd generation. That means they are not resting o their laurels.
Personally the Prius' styling is too much for me to handle as an owner. I'd be way more happy getting 40 mpg in a Camry hybrid. Ok, it's not just exterior styling that turns me off either, but the interior ergonomics are goofy. I dislike the center stack gauges....whether it be a Scion xB, Prowler, or a Mini.
"They" point to marketing research suggesting people who want a hybrid want it to look different than other cars. Not me.
· TN Member
Prius
Discussion Starter · #9 ·
Well, that's why there's the Camry, right? For the mainstream folks.
I mean the TCH has its merits. You get a LOT more luxury features for only a bit of mpg. It's also a better highway cruiser (quieter and more comfortable) and more luxurious. And that's good, cause then the two vehicles can target different demographics without too much overlap even though they're priced similarly (at least in Canada. I think the US Prius has a $4k headstart on the TCH right?).
15 Ram 1500 Diesel
If you get 60 you are in the minority. By that I mean you are the first person I have ever seen to claim near 60. I have had ONE customer claim 50 as a max. Most see 45 average if lucky. In my area the Pocono mountains are lumps compared to the PNW. 40-42 is more the norm here. I had people who traded gen1 Prius on Gen2 who wanted their Gen1 back because the mileage was better. If you have a heavy foot I have seen them in the low 30's. A Camry Hybrid at 40? I have never seen it and I doubt if I ever will.
The emissions issue while important is overblown. A standard PZEV camry is extremely low as well as are many other cars. The next generation of "clean" diesels are excellent too. Also no matter what the commercial shows, bunnies and trees do not come out of a Prius tailpipe. The overwhelming problem with emissions is lack of maintenance and/or poor quality/incorrect maintenance. Just because the MIL doesn't light up is meaningless.
You mention the Lupo etc. I do not want that car. I would like to see a Rav 4 Turbo-diesel here in the US along with a Corolla and Camry Turbo-diesel with some legroom.
The Prius is an expensive small car. You can do nearly as well for far less with a Yaris or Corolla stick. It takes quite a while to recoup that money laid out in MPG.
They (Prius) require specialized training to repair. They do have issues just like anything else. You cannot just take them to the corner garage. Well I guess you can but that doesn't mean they will be repaired correctly.
Try towing something with a Prius-not recommended btw- or for that matter ANY hybrid. Friends towed 2 motorcycles to Daytona with a Highlander hybrid and averaged 12 mpg with a low of 9! Great mileage huh? My Tacoma V6 towed 2 600lb ATV's, a 600lb motorcycle and a 250lb dirtbike plus 2 adults and gear to Canada by way of Maine and VT 3 years ago and averaged 14. I have several friends who tow with their VW diesels and average mid 30's while towing.
On my post about my VW I believe it was misunderstood what I was referring to by POS. I was referring to the VW. While the engine is great the rest is junk. VW does not have near the build quality of Toyota.
All I am saying is that a Prius makes no sense at all to me for my needs. Perhaps for you they do.
Thank you for adding that final point, that the Prius makes no sense to you, but that it may make sense to other people. I see the Prius as a technological leading edge, and as a transition from our current, high fossil fuel use ways, to more responsible habits.
Technological leading edges are always expensive, and there will always be people who think they make no sense whatsoever. Just think back 20+ years to when portable cellphones were being introduced. They were big, bulky, heavy bricks with batteries that only allowed you to talk for a few minutes before requiring recharging. A few leading-edge people bought them, but most people were asking "what's the use"? But enough people bought them so that the cellphone manufacturers like Motorola put more investment into designing better, smaller, lighter ones with much higher-density batteries. And where is the cellphone today? Almost everyone has one, and some people rely on them so much that as soon as service becomes unavailable, they cannot go about their usual business (witness the crash last year of the North American Blackberry service).
I see cars like the Prius as comparable to the cellphone. As they have become more mainstream (witness the Toyota Camry Hybrid, the upcoming Saturn Dual-Mode Hybrid, etc.), more and more people will start to think of them as answers to the big problems such as pollution, and not just a "what's the use"?
· TN Member
Prius
Discussion Starter · #12 ·
60 is my max and yes I am in the minority group. Most of the 60mpg folks are in Texas and Florida (just looking at the PriusChat folks). You are correct that the average person will get mid to high 40s and touch 50 on a really good day. You just gotta learn how to maximise mileage and frankly a lotta people are happy with 45+ cause their previous vehicle was in the teens or 20s.
A PZEV Camry is the same, yep. I checked my exhaust pipe at 30,000km and 60,000km. I was damn surprised how clean it was. On our ULEV Camry, my paper towel would've been deep black. On the Prius, it was grey.
I didn't mention a Lupo did I? But yes I was referring to that. Like you, I wouldn't drive it either. The Prius gives me the features, space and the convenience of petrol while getting similar mileage. Isn't that an achievement?
It's not a small car, it's a midsize, two classes above the Yaris, one above the Corolla.
Well ya, it's not meant for everyone. I mean someone trying to convince me to get a HiHy won't do any good cause it's makes no sense for me to have 7-pass SUV. I don't need one, hybrid or not.
15 Ram 1500 Diesel
One difference, I have worked on them and I know them in a technical aspect being a former MDT.
Here is another, more skeptical, viewpoint.
Bottom Line
The Prius is not a great car, but it does serve its primary purposes - saving fuel and advertising Toyota's environmental leadership - better than almost any other vehicle on the market. The lack of engine power, numb steering, indifferent handling, and the "look, I'm a tree hugger!" exterior appearance would prevent me from owning a Prius. I was, however, very impressed by the fuel economy (typically between 44 and 47 miles per gallon on my commute that usually makes my V6 Accord get between 22 and 23 miles per gallon) as well as the impressive technology that underpins the Hybrid Synergy Drive system. I'd be curious to try a Toyota Camry Hybrid for a week, which probably gives a more "normal" experience with only a small penalty in mileage and none of the "baggage" that some associate with the Prius.
The full article is available at: http://www.autosavant.net/2008/02/2008-toyota-prius-review.html.
· Tacoma Rocks
So, u need a prius??? Somehow it may sound obvious why u bought a prius? but in the end I´ll ask it.
1 - 15 of 15 Posts
