On Friday my Toytec 3" 884 coil, AAL, Rear Axle degree shims, Driveshaft carrier bearing drop kit was installed and on Saturday morning I took my truck to the Toyota dealer to have the alignment done.
This is what I discovered;
The installer insist that it was the lift that cause the boots to tear. I have been talking with Toytec and they told me after 10000 installs of the same type of lift. Have not see this type of issue. I have decision to make. Should I have the installer fix the problem at no charge or minimum charge to me or should have the Toyota dealer fix it and charge the installer the $700 the dealer going to charge me for the repair? I got the lift installed at www.fao4wd.com Just remember that the installer insist that its the lift and that he did not tear the boots on install. Comments are welcome. Thank you, Don
