1 - 3 of 3 Posts
I am having a problem with my 98 corolla. When im going about 40 to 50 mph and i start turning to the right i hear this sound as if something is grinding. It sounds like metal work done on a lathe, and i believe its coming from the front. My right rear rim is bent a little so i dont know if that could be causing any problems as well. Any ideas would be helpful.
Check your brakes.
Pads might be worn out or your rotors have a rust ridge in the inside.
Could also be rust build up in the rear drums.
the front brakes are fine as far as i know they just got put on in october, but...could very well be the rear brakes
1 - 3 of 3 Posts
