1 - 6 of 6 Posts
I need help!
I have a Toyota Camry 2000 V6 with 30K on it. When I start the car first thing in the morning (the engine is cold, of course), it starts right away, rpm is about 1800. But when I shift to drive gear or reverse gear the car chokes, hiccups, hesitates like it wants to die. After 10 minutes of driving when it reaches the normal operating temparature, the problem improves 90%, then it only occurs when going up the slope.
I have changed the spark plugs (twice:with the irridium, then back with the platinum with twin ground electrodes), spark plug wire, pcv valve, spray the throtle with cleaner. Still the problem persists.
Please help!!!
just re-read ur post, and the above probably won't help..but it cant hurt:p
have u checked for any error codes?
Cressida nut
91 Pickup (Hilux)2wd
or injectors or pressure regulator. if it improves as the engine warms, i would tend to think its in the engine bay.
is it still under warranty? if so take it to the dealer
Discussion Starter #6
I checked and cleaned the iacv. The car is no more under the warranty. Yesterday the check engine light came on, so I took it to dealer for a scan, they said nothing wrong with it.
1 - 6 of 6 Posts
