Part Dues,
The alignment is good. So here are the initial results. Again, main concern was Z axis. I can make them go up or down easily.
First, Acura TL
Second, Morimoto
The height or aim up and down are off because I need to remove the headlight to aim the TL but Morimoto I can do by hand. I didn’t think of taking pics of the aimed Morimoto tho lol. I have a list of things to do to complete the build.
1) Make new wiring for second relay because my current wiring setup won’t work. Hence, the reason why I can’t switch all lights on for show. I’m excited to say that I’ve found a cheat code while thinking about the final wiring job.
Cheat sheet: one single MotoControl relay system powers a pair of Bi-Xenon projectors. To activate low or high beam you need only one driver side input from stock harness. So I will instead wire all high beam using one relay mainly because high beams are very low power to activate. Then, I will gain on the second relay a free spot to activate fog lights instead! This is ganna be fun. More later.
2) Upon further inspection I will need to cut the shroud a little more based on my lens fitting sessions. Unfortunately, it’s in spots I hoped not to cut but it is what it is.
3) Clear coat the lens & seal the lens.
4) Carbon or fiberglass the rear end to cover.
First, Acura TL
Second, Morimoto
