Hey Guys - Where is the proper place to put your car lift pads on a 2008 ES 350? I'm assuming 2008 Camry similar frame setup. I was unable to get the rear pads onto the flat area just after the pinch weld. pads are too big to fit in there. I ended up putting the rear on the frame that runs all the way to the front, and then in the front, put on the flat area just outside the frame. it seemed more stable than just using the frame. Is there a better way?
