1 - 9 of 9 Posts
So my 2003 Highlander got the dreaded P0325 code. Tore it down and pulled the sensor. I have a data system that can read the output signal from the sensor and when comparing the Bank 1 that was bad with the Bank 2 that is supposedly good it was pretty clear (or thats what I thought at the time) . The good responded with a nice decaying 7.5kHz ring when hit but the bad one was intermittent and had a lot of noise.
I purchased an aftermarket one at O'Reillys and tested that with the same setup. Signal looked good but was at a bit higher frequency. I figured that would not matter. Installed it and took for test drive. P0325 popped up in a few miles.
I can probably pull it in a hour and put it back in 2 hours now when it is fresh in memory but I ham hesitant dumping $450 on a pair of OEM sensors until I am sure the sensor is the issue. I left the dreaded M10x1.25 screw in the back out.
By the way, the trick for that *(@#& screw is a short 14mm socket and Harbor freights PITTSBURGH 1/4 In, 3/8 In. Drive Long Reach Dual Flex Head Ratchet. The 1/4 end on the same ratchet and a 10mm socket does well on the clamp next to the throttle body holding the fuel line. I followed Haynes and left the throttle body in the car.
However. I am not 100% sure a OEM sensor will fix it. The cable was in good shape, the old sensor was bad but I was able to test the new one and it was not dead on in output. I replaced the harness too. Reinstalled the Bank 2 stock sensor.
I'm tempted to make a jumper harness to swap Bank 1 and 2 between the sensor harness and the main harness. Does anyone have an idea on where I can get the mating connector for the harness? Does Toyota sell them? Would a scrap yard cut a connector from an engine?
Below is some measurements I did on them. I figure it can be of use for someone.
Thanks,
Tribologist
2003 Highlander
2010 Sequoia
I think I understand what type of sensor they are. They are similar to what was known as Shock Pulse Sensors for monitoring bearings. Its a Quartz crystal and a mass with vary little damping. They act as a tuning fork at 7200Hz and will start to ring if it is impacted. Kind of make sense :) It makes it easy to interface with a simple cirquit that senses voltage and the voltage will be proportional to the amount of shock energy. One can probably test them by hooking them up to a headphone and tap on them or make a cable so you can hook them to the sound card in the computer at the line input. They should ring like a very high pitch bell when getting an shock.
Here is the output of the good sensor. The right plot is the voltage over time. The left plot is a FFT, it show how much of a signal is at a specific frequency. A pure tone gives a spike like this. Note it is at 7200Hz.
Slope Rectangle Line Font Parallel
Here it is zoomed in a bit. You can see the voltage swing. The sensor is actually not outputting a voltage. it is outputting a charge. The voltage is totally depending on what is used to measure with. I'm using a data system that loads the sensor very little.
Rectangle Slope Line Font Parallel
Here is the output of the Bank 1 (Bad sensor) You can see its intermittent and noisy but at 7200Hz.
Colorfulness Slope Rectangle Line Font
Here is the O'Reiley "Import Direct" $69 sensor. Clean tone but at higher frequency. About 7640Hz.
Colorfulness Rectangle Slope Plot Font
2003 Highlander
Discussion Starter · #6 ·
Thanks Hayabusafalcon
That's pretty much the plan, at least for starters. That's why I like to get the mating connector. If I get that I can swap the two and see if the error move to P0330 and I can do the hack without cutting any cables. I have the knock harness side connector from the old knock sensor harness, I need the one on the engine harness. I called a few junk yards and they would not cut a connector out of a 3.0 V6. Those engines are not sitting on the shelf and he rarely get a car with blown engine and the blown engines ends up on the regular scrap yard as scrap metal.. There is a pull place in north end of town that I might go and check. they don't even list what cars they have. Its easy to get to from under the airbox. (to cut that is, not easy to clip loose. I broke it of and zip tied it...)
Tribologist
Discussion Starter · #7 ·
Found this Harness repair manual and the part number of the connector The one on the harness is marked 11268 so it mates with a housing 90980-11269 and use terminals 82998-12440
Housing and terminals is about $35. Going to check at my local Toyota if they have it. With that I will make a breakout harness where I can Supra Hack or swap Bank 1 and 2. Will be fun.. You always learn something. I really appreciate to find information on this forums and I do my best to share back I never been really active on the Toyotanation since My Sequioya and the Highlander just keep running but the Highlander has 238k on it now and the Sequioa need a new transfer case actuator..
Here is the connector information.
https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
Rectangle Font Parallel Slope Pattern
Product Rectangle Organism Font Circle
Rectangle Font Parallel Circle Pattern
Rectangle Font Parallel Screenshot Number
learn
Connectors can sometimes be found by Toyota part number on Amazon, or
Discussion Starter · #9 ·
Thanks, I ordered at my local dealer. Should be here by end of week. It will be interesting to see what the signal look like when driving.
1 - 9 of 9 Posts
