Hello,
My Highlander (2015) got a battery warning light this week (turned on for a moment and then went off, again and again for about 30 min. The next day it did not appear). I bought a battery tester and tested the battery which I bought on Dec. 2021. The test result shows that the battery needed to be replaced. The follow are the test result data:
State of Health = 53%
State of Charge = 100%
Test Value = 512CCA
Battery Voltage = 12.63V
Internal resistance = 5.80 mOhm
Test Result = Need to be replaced
I went to the shop where I bought the battery and got a replacement (same battery, brand new).
Before I install the new battery in my car, I tested it out-side of car. The results are:
State of Health = 70%
Test Value = 584CCA
Battery Voltage = 12.70V
Internal resistance = 5.10 mOhm
I was wondering why a brand new battery needs to be replaced. I thought may be I had to give it a charge. I did not return / change the battery at the store immediately.
Today, I drove my car for about 2 hours on highway (about 80 miles). After 2 hours I stopped driving, I tested the battery again. The results are:
State of Health = 71%
Test Value = 589CCA
Battery Voltage = 12.82V
My question is: Are the test results true? Why a brand new battery need to be replaced? Which item in the test result data is bad? Do I need to return/replace the new battery I got yesterday?
Thanks for any advise.
Bob
Test Value = 512CCA
Test Value = 584CCA
Test Value = 589CCA
Bob
