1 - 2 of 2 Posts
i did SEARCH but didnt get the answer i wanted...
ive had my 1993 camry v6 xle (3vzfe) for about 3 years now, and i wanted to ask if its hard to change the timing belt on the 3vzfe v6? or should i go to a local repair shop?-how much would it cost?
Grenaded piston
If your asking how to change it, your better off not messing with it.
Changing the timing belt is not a simple task. You gotta make sure you have everything (both cams and the crank) aligned properly before the belt even goes on.
Not trying to discourage you, but unless you know what your doing I'd leave it alone.
http://www.yotarepair.com/Timingbeltinstructions.html
1 - 2 of 2 Posts
