I have a 2000 Landcruiser and recently while away the engine lights came on. I went to the nearest station.. The mechanic ran a vehicle diagnostic report. It showed that cylinder #7 was mis-firing and that my 02 sensor was going. He replaced the cylinder at a total cost of 365. I was able to get home safely, it was a 100 mile drive. He told me to take and have car checked out completely when home and then have 02 sensor replaced.
I then took vehicle to Toyota, knowing it was also due for some major service. It has 92,000 miles on it. I think they wound up pratically rebuiding my truck because I walked out 4000 poorer. They replaced 2 coils, bank 1 sensor, timing belt, water pump, etc....
Anyway, when I picked up truck they told me they replaced cylinders # 1 and #7. I told them #7 had just been replaced. They guy behind the counter became very uncomfortable and could not look me in the eye, he told me he would check with his mechanic and call me. He called me and I went back. They handed me a part and told me it was defective. He told me sometimes this happens, that parts go bad. I said in three days? And I was able to get home from vacation with that part. He also pulled up the vehicle diagnostic report which showed the 02 sensor and cylinder 7 misfire. It also had a Y int he freeze frame section next to these two items. All other freeze frame had a N. My question... as I do not trust the Toyota dealer... Do you think there is a chance the first mechanic did not re-set the code and freeze frame data knowing I was going to take it to the dealer when I got home? Did the dealer replace a good part? Any feedback would be appreciated. I have spoken with the first mechanic and he thinks something is fishy.
