By nipple I think he means the lower radiator outlet. If it is warped, I don't think there is much you can do short of replacing the radiator. But, if it is warped I imagine that you should be able to feel it.
It might be worth throwing on a second hose clamp on and cranking them both down as tight as you can get them. If anything this will slow the leak.
If you really doubt the mechanic, just ask to have the original radiator returned to you after the new one is swapped in. Or be there after he bleeds the system and pulls the hose.
-Frank
-Frank
