1 - 20 of 20 Posts
poor college student
I have been researching nitrous systems and I really only have 1 question: with a dry nitrous setup, how is more fuel delivered through the injectors?
Reppin my Home
With a dry system, the fuel is injected through the intake manifold I believe. Unlike a wet system, it can sometimes be uneven distrobution between the cylinders.
I'm not really a No² buff, but i know a couple things :\
it isnt. your thinking of a wet kit
Discussion Starter #7
97 camry xle said:
lol uh oh... not another... hope this one doest go the same way :lol:
What are you talking about, n00b!? I am asking a simple question, not running 200shot nitrous on 2 cylinders and 2x the fuel on the other 2 cylinders on a 3SFE, nontheless.
Oh and FYI, the person who made that thread was from another forum and trying to get us all pissy.
Discussion Starter #8
"Nitrous pressure is fed to the nozzle and the back side of the fuel pressure regulator diaphram, thus incresing fuel pressure."
So what is this fuel pressure regulator diaphram? Is this the MAF?
3s-gte in a Camry?!?
'89 Camry Alltrac
Any nitrous system will add extra fuel to the motor at the same time as its adding the nitrous (otherwise your motor would blow just about immediatly). A 'wet' system has its own fuel injector, as others have stated. A 'dry' system raises fuel pressure so that the stock fuel injectors spray more fuel.
The diaphram that they are talking about is in the fuel pressure regulator, which sits on your fuel rail (where the fuel injectors get the fuel). Regulators are referenced to manifold vacuum and adjust fuel pressure based on vacuum. By fooling the regulator with extra pressure on the regulating diaphram, you can make it provide higher fuel pressure.
If you stay with a very small shot (like 25!) you can go with a dry kit. If you start to go bigger, seriously think about doing it right with a wet system or even a full direct port setup. Don't be stupid and blow your motor right away.
Hope that answers your question.
-Charlie
haha no shit, im not saying anything about you, i was just merely saying that in the last thread about this topic everyone got all pissy, so chill....
Discussion Starter #11
-Charlie
Thanks for the info man! I had no idea that toyotas regulated fuel that way!
I was planning to only run a 35 shot for ~10 seconds.
'89 Camry Alltrac
All fuel injected cars regulate fuel that way... All normal ones do, at least.
If you are worried about it, find a reputable shop to install the nitrous for you. Talk to a few places before making any decisions...
-Charlie
Discussion Starter #13
I'm building the setup myself.
It will end up being a 25 shot, if anything.
white90dx; you know if a paintball co2 tank will store nitrous safely?
'89 Camry Alltrac
Please don't cheap out when it comes to your motor. Buy a well designed kit...
-Charlie
Discussion Starter #15
It's not hard to fabricate a nitrous system, as long as you purchase good equipment.
'89 Camry Alltrac
You have yet to give me any faith that you know enough about cars to fabricate anything... That's why I suggested that you buy a pre-built well designed kit... I'm just looking out for you, man.
-Charlie
Wet vs Dry
-Charlie [/B]
A wet kit is NOT better than a dry kit. A dry kit doesn't send fuel where it isn't supposed to be (IE, throttle body, intake manifold, intake). Plus you aren't plumbing into your fuel line, which means less that might go wrong on the install. Go talk to a performance shop, and ask them. Every one I asked said a DRY kit is better unless you are running a turbo motor.
Grenaded piston
It probably will, but the problem is finding someone to fill it. They'll say this tank is not approved for nitrous, so we can't fill it.
Your better off buying a small nitrous bottle.
Discussion Starter #19
-Charlie
Is this supposed to be an insult? And for your information; I know quite a bit, and I research quite a bit, and if I am unsure of something I will post here and ask.
I appreciate you looking out for me, but I don't appreciate how you insult my intelligence.
'89 Camry Alltrac
The questions you asked me in PMs showed me that you haven't done much research. If you believe it to be otherwise, that's your opinion. Go talk in person with those who have successfully used nitrous on their own personal cars and also with places that have successfully installed them on cars if you want to be safe and smart about it.
I'll be very happy for you if it works out for you. I will also feel bad if you didn't heed the advice of the people on here and you blow your motor.
-Charlie
1 - 20 of 20 Posts
