1. There is a chirper on the factory alarm, but I can't remember the procedure for re-enabling it off the top of my head, but google can probably tell you.
2. You definitely have factory installed anti-theft if you've got the remote, if you've got a Toyota security indicator next to your window lock switch you've got the better one of the systems.
3. The Celica isn't going to be a quiet car in terms of road noise, but I would replace those tires based on age. I've got a nice pair of Bridgestone Potenzas on mine.
4. It's not going to be as simple as just plugging something in, you've got to run a few wires for power and the temperature sensor, but it's fairly simple. You can buy one new from Toyota in a kit, the part number is PT374-20030 (runs about $210 on toyotaoemparts.com). I've got the install manual, which I'd be happy to scan for you if you need it.
5. There's not much you can do to make a GT faster, but your best bet for a little bump is to throw a cold air intake on it.
6. There are a few kits that allow you to connect an iPod to your factory radio that use the plug for the CD changer on the back of the radio. Search around for an auxiliary input adapter.
