1 - 13 of 13 Posts
Hey guys, I have a 05 highlander limited since spring started to come around I notice the suspension and steering getting loose and to bouncy so shes about due for new struts front and rear. I need to replace as well the lower control arm bushings.
Anyways on to my question I was on rock auto and they have the monroe quick struts and they have the gabriel brand quick struts. The gabriel brand they only have for the rear but if I search for a 05 rx300 awd they have the fronts and have the same part number for the rear.
I'm assuming that rx300 and they highlander share the same struts?
I dont wanna order something and not be the same thing you know
Thanks.
What does the Gabriel web site say? That should be definitive.
I have about 10k on Monroes. I find them a little stiff but no big problem
2001 Camry LE
I've heard that the Monroe struts are okay, but to avoid the Gabriel brand struts. I have Monroes on my Camry and no complaints.
I also have the monroe quick struts but there the economy type quick struts and there great but I figure I would get a little bit more o.e quality. I've never used gabriel but I've never heard anything bad about them maybe I'll just fork out a little bit more to get the monroe and quit messing around.
HI,
It should be covered on here or online whether the RX and HL struts are interchangeable.
And as you noted if the part numbers on the Gabriel and/or Monroe websites show they interchange then you're 'golden'.
My guess is they probably are, BUT the Lexus I drove when shopping for my HL was a much softer ride, so I'm thinking they're valved differently, even if they fit/install the same.
GL,
TD
If you live someplace with a harsh climate and road salt, quick struts are the way to go. They aren't that much more than struts only and give you all new components. I guess I'd choose the KYB assembly, they are the oem manufacturer.
My 07 has new front struts, don't know the brand or whether they were quick struts. Living in Tucson, I don't choose quick struts. Changing out the struts using the original springs & other components is pretty easy. If you have access to an air impact, it's about a 15 minute job once they are on the bench. And the other components here are rust free. Only thing I always do is clean and repack the bearings. Grease is free and I have a cleaning tank. Because it's so cheap to do, I generally go for way off brands from Rock Auto:smile:. I ordered some for my 07, rears only, are OSC brand at about $48 each. Autozone will loan me a spring compressor.
2003 Highlander
+1 on what Brian says. My original struts were a mess when I rebuilt them six or seven years ago. Sandy-rusty mess. I'm glad I had purchased all components (KYB) including the rubber stuff when I did that job. BTW-I have since gone with quick struts to my delight way easier to install. The (front) one's (cheapies) I got from 1A Auto this past winter have held up nicely so far. I'll update my ongoing string on QUICK STRUTS as the miles add up. Haya....:my2cents:
I did my rear struts, finished them on Thursday. In retrospect, I wish I'd gone for the quick struts. The rubber parts on my struts are semi-perished. I had to get new bellows & bumpers--got lucky, O'reilly had them in town, so the wait was less than a couple of hours. Got them back together and on the car, even the cheap struts are such an improvement over the worn out ones. And I've gotten pretty good at changing them. The car came with new front struts, so all four are now done. Sometime in the next 6 months, I'll get a 4 wheel alignment.
As my username suggests, I live in the Sonoran Desert. All the fasteners were slightly oxidized, a breaker bar with a cheater pipe helped break them loose. Just a suggestion for those that live in the rust belt, the old thing about "California cars" is almost true. The really rust free cars come from the deserts of Arizona. My 07 Highlander looks like a new car underneath. And, for some reason, it was undercoated. Truly remarkable.
2003 Highlander
Brian, unless you suspect damage or something bent in the rear end components you really don't need the rear end aligned. It's just a toe-in/out adjustment anyway. The front is another story. If new front components were installed then yes get the front done. Again it is just a toe adjustment. No camber adjustment on these HL's. Of course it's up to you just maybe save a few $ on the rear.
BTW-there is maybe an advantage of the rust that accumulates up here in the salt belt. I just replaced a control arm on the rear end of my 2003. Let met tell you that adjuster was rusted solid. Ain't no random movement back there. Period. The rear has never been adjusted and is still factory spec! haha.
Haya....:smile:
Haya....:smile:
Haha! I've seen pics of frame components that looked like they were stored IN the Atlantic. My brother had a Nova in Lansing that had a rusted thru valve cover! My 5 year old Corvair, when I was in HS, you could see the pavement thru the big hole in the floor.
I don't miss Michigan, much!
イリジウム
Monroe’s website isn’t loading for me. But find part numbers there and search rather than depend on rockauto catalogs.
If QuickStruts are available I wouldn’t bother with spring compressors, as rubber parts (including mounts) often need replacement too.
2003 Highlander
Oh, I know what you mean. I once had a Plymouth Volare wagon, brown, company car, ugly as sin. The tops of the fenders rusted through in 9 months from brand new. True. Water and mud would fly up onto the windshield. If you see one of those K cars nowadays it's a rarity. They crushed most of them. Good riddance. Haha.
Haya....
Look beyond the marque
If you buy OE, the struts for the Lexus and Toyota are probably valved differently but I could be wrong.
Regarding aftermarket struts for your HL, they do fit the RX and valved the same.
In my opinion, if the original coil springs have no major signs of damage/rust/sagging, I would re-use them when rebuilding with the new struts and other new hardware.
The factory coil springs can be a chore to compress evenly. If you go DIY, I would suggest buying (2) two interchangeable fork coil spring compressors (Ebay, Amazon, or Summit Racing).
1 - 13 of 13 Posts
