1 - 4 of 4 Posts
Hello, My rack & pinion gear on my 2000 Sienna is moving because the mount bushings have wallered out, so when you turn the steering wheel left or right before the rack even comes out, the whole rack & pinion body moves. It could very well be that the rack & pinion assembly is shot and needs to be replaced. If it does I may take a stab at rebuilding it with a seal kit. I do a lot of this sort of thing so I could probably handle the job. But if I can't get and install new mount bushings, then it's a waste of time doing a rebuild, so my question is: Do you know where I can get the rubber bushings and can you tell me how to install them? Thanks so much for your help, Pat W
1 - 4 of 4 Posts
