Okay, my ABS light comes on after I start down the road and stays on. When I start up my vehicle it does the usuall bulb check on and then off. I have been following these instructions to get the ABS codes "On the 1993 and newer Camrys, you’ll have to find the DLC1 and DLC2 data link connectors. DLC1 is located on the right side of the engine compartment near the firewall, and the DLC2 connector is inside the vehicle under the dash on the driver’s side. With the ignition on, remove the short pin jumper from DLC1. Then connect a jumper wire between terminals Tc and E1 on DLC1 or DLC2. This should cause the ABS warning light to start flashing out any codes. If there are no codes, the light will flash continuously twice a second.". When I do the jumping the only thing that flashes is the airbag and cruise lights. I cannot get the ABS light to flash anything. I have double checked my wire jumping and used the DLC1 and DLC2 and both yield the same results. Here is the full article incase you can spot somthing I dont
Breaking Down ABS Service . Can anyone help me get these darn ABS codes. I want to do this myself.
Thanks.:disappoin
Thanks.:disappoin
