2007 Camry, I4, 156000km
For some time now, when i accelerate i hear this faint pinging/rattling sound which sounds like its a pulley rattling or some sort of chain that is loose. It mainly happens when i start from a complete stop and even sometimes when i press the accelerator while cruising. I hear the noise more when the windows are rolled down and it sounds like it coming from underneath/front of the car.
I have changed the accessory belt and checked all the pulleys for tightness and they seem pretty tight, no wobbliness. I have gotten a dealer to check it out, and they told me it was the flex pipe, i had it changed and still hear the noise, this was quite a while ago. Also no leaks from the water pump area.
The sound can only be heard when the car is in motion, and if i put it in park, or N and rev the car there is no sound. I have heard that it could be suspension related and i have had a mechanic check the suspension and he says he cannot see anything wrong. I even tried to run premium gas in the car to rule out engine pinging, and sure enough the noise persists with 91 octane gas.
Could it be related to transmission? I do a fluid drain and fill every 30,000km. And the fluid always looks new and does not smell burnt.
Any ideas on how i can get to the bottom of this noise?:dunno:
