1 - 2 of 2 Posts
On a scale of bad to junk it now, how bad is this? Was a northern 01 sports edition for most of its life. Needs shocks, brakes, and timing belt done. Wondering if it's all worth it. 175k on the clock. Looking for feedback, tips, thoughts.
Thanks
284673
284674
284675
284676
I'd rate that as: "mine ('99) is MUCH worse" and still going strong.
Are there any holes that need to be patched? My test is to poke around with a screwdriver and see if it goes through anywhere, it doesn't look like it would on yours.
I already had to rebuild that panhard rod pickup on the diff and patch the frame rail in two spots on the driver's side near the fuel tank. Check that area well - between the fuel tank and frame rail.
I'd guess you have at least a few more years on that before you are there.
1 - 2 of 2 Posts
