1 - 5 of 5 Posts
CELICA GTS 240HP
Hi guys,i have a toyota rav 4 model aca21 equipped with engine 1az-fse imported from japan,runs smooth when cold but when engine temp reaches 82 degrees celsius the engine rpm drops to about 300 rpm and on most occasions the engine stalls,i contacted toyota japan about this issue and they replied that the ecu must be reprogrammed with an updated ecu calibration file,anyone knows were i can find this file?
CELICA GTS 240HP
Problem Is That The Dealer Only Has Reprogram Files For European Spec And They Cannot Help With Japanese Spec!
99 Rav4 AWD
The program is Toyota specific.
That would be the unfortunate thing about having one from another country.
CELICA GTS 240HP
any solution guys?
the good thing is that i have in my possesion both factory hand held testers of toyota (vetronix tester and denso intelligent tester 2) so reprogramming is not a problem, the only thing i need is the reprogramming files.
1 - 5 of 5 Posts
