Hello everyone! I seem to be having a slight brake problem. When I bought a brand new Toyota 2005 RAV4 the brakes were good because I didn't have to press down it on that hard. However having it for 5 years, when I press down on the brakes it almost goes all the way down to actually stop the car. It feels like the brakes have been "loosen". So here are the steps I took to diagnose the problem: 1. When the engine is off, I press down on it and it's really hard. (So that's a good thing right?) 2. When the engine is on, the problem persists as described above. 3. I checked and there weren't any leaks whatsoever. 4. I replaced the brake fluid and it still has problems 5. I replaced my rear brake pads, I'll be replacing my front pads soon. Is there any things that would solve this problem and not make my brakes spongy? Thank you!
****** SOLVED ******
Okay after wasting about 200 dollars replacing the master cylinder, bleeding, etc... I found out the problem!
It seems that the brake pin (or whatever it's called) was rusted, and after just cleaning it away, the brake pedal was not spongy anymore!
