1 - 9 of 9 Posts
G
Re: 1992 Toyota Camry Radio Problem
Does it light the dial? Does the antenna go up? If not, you need to
get a volt meter and check the power distribution. You can find a
wiring diagram on the net.
AEscalante wrote:
> Hello.
> I have a 1992 Toyota Camry, and the car was my mother's before it was
> mine. About ... 2-3 years ago the radio went out one day will she was
> driving. Anyway, last year I bought the car from me her, and have been
> using portable radios for my music and news needs. But, a friend
> recommended that I check the fuses just in case one of them is out, so
> I do. I checked all of them that had to do with the radio, and non
> were blown, so I changed them anyway (all of them, just so I know when
> the last time fuses were put in). And now the radio still does not
> work. The fuses I changed are the ones under the hood, and the ones on
> the driver side, but to no avail. Does anyone have any suggestions?
> Any help would be much appreciated.
> -- Alejandro
G
Discussion Starter · #2 ·
Stubby:
It doesn't look like there is any power going to the radio. The dial
doesn't light, and the antenna doesn't go up. I press the power
button, and it just sits there. I found the EWD for the '91 models,
but not for the '92. They look almost identical in style, do you think
I could still use the '91 in the stead of the '92?
G
Discussion Starter · #3 ·
I have no alarm for the car. But I need help finding this battery you
are talking about. Where can I find a manual that will help me
further? Or could you possibly tell me more specifically?
G
Discussion Starter · #4 ·
On Wed, 27 Dec 2006 21:03:35 -0800, AEscalante wrote:
> I have no alarm for the car. But I need help finding this battery you are
> talking about. Where can I find a manual that will help me further? Or
He means the battery in the car...
Now Toyota's wiring is proprietary, so the colors are different. If you
have the manual page, it should list the connector and connections. Go get
a cheap V-O-M (volt meter) if you don't have one, if you can get one with
clips as well as regular leads; clip the black wire to something metal
attached to the frame of the car, and use the probe on the connector.
First, leave the carr OFF totally. You should find one connection that has
+12 volts on it. This is the 'Back-up' that holds the stations in memory.
Depending on who made the radio, it may or may not be needed for operation
(Radios were made by National (Panasonic), Fujitsu and Clarion. I believe
the Fujitsu needs the Back up operating...)
If you can't find +12V this way, this may be your problem. IIRC, you said
you checked the fuses; did you look under the hood? There is a 7.5A fuse
there that, IIRC controls this connection. If all this is good, turn the
key to ACC and check the connector again. You should now have TWO +12V
connections. If not, this is your problem.
If both these are good, you /may/ have a blown fuse inside the radio!
These can be a REAL pain, since they usually look like a green or blue
resistor and are usually soldered onto the circuit board. The CKT BDS are
CHEAP, and you can easily lift the pads trying to install a new fuse. I
have YEARS of soldering experience on NASA stuff, and these things STILL
throw me for a loop. I send them to United Radio (Toyota's Warranty Repair
Center) in Upstate NY; for a nominal fee they swap the radio out.
Good Luck! Let us know what you find!
BTW, I have had ONE toyota that had the original radio that did NOT go
bad; that was a 1974 Corolla 1200 I bought new with a Clarion AM/FM MONO
radio. On the rest of my cars, I have replaced the stock radio with
something better.
I have bought 4 used Toyotas in my life, and when I replaced the radio,
EVERY ONE of them had a sticker from United Radio on the radio, and a
warranty sticker missing from the warranty book!
G
Discussion Starter · #5 ·
<a href="http://photobucket.com/" target="_blank"><img
src="http://img.photobucket.com/albums/v253/xxalejandro/DSC00404.png"
border="0" alt="Photobucket - Video and Image Hosting"></a>
These are the car's harness wires.
src="http://img.photobucket.com/albums/v253/xxalejandro/DSC00403.png"
These are the cables that come out the back of the new radio I bought.
Now, how do I connect the two? Do I have to cut the wires and connect
them to their mate on the other?
Thanks much for pardoning my poor English.
G
Discussion Starter · #6 ·
> border="0" alt="Photobucket - Video and Image Hosting"></a> These are the
Well, I WAS hoping to post something to halp you out, but you've now got
me stumped!
I went to Wal*Mart and bought one of those connectors, because I *MAY*
want to swap the radio out of my Scion (What? A Scion with a STOCK radio?!?!)
But, I actually like the sound. Wal*MArt didn't have any of these
connectors (Model TA021) on their Web Site, so I wanted to get one before
their discontinued.
So, looking at the picture "DSC0404.png", the connector on the LEFT we'll
call Connector 1, and the one above your thumb we'll call Connector 2, the
wiring goes like this:
On Connector 1:
(I Hope the pic isn't reversed; I'm looking at MY connector as if I were
going to plug it into YOUR connector...)
The Top Left pin is Purple. This is Right Rear +
Then there is a space, and then the keyway. The next pin, top right, is
Green. This is Left Rear +.
The bottom row, from the left: Purple/Black, Right Rear -
Blank
Blank
Bottom row, right Green/Black, Left Rear -
on Connector 2:
Starting from the left top:
Grey. This is Right Front +
White. This is Left Front +
Keyway, then blank
RED. This is +12 V from the ACC connection.
Yellow. This is the +12 V BATT connection, always 'ON'
Bottom Row from the left:
Grey/Black. This is Right Front -
White/Black. This is Left Front -
Black. This is GROUND
Blue. This is Power Antenna. This is an "As Needed" wire, or to turn on an
external amp.
Blue. Also Power Antenna. This will provide the power through
the harness to the antenna.
Orange. Dimmer. This is what causes the radio lights to dim when the
parking/head lights are turned on.
Now, the stumper. The OTHER harness you're showing me from the radio does
NOT appear to be a Toyota harness! In looking at your picture, it looks
like someone spliced this connector onto the radio. They DID have one of
these at Wal*Mart, and it was marked "Generic Import Adapter", and was
listed for certain models of Nissan, Honda, Subaru, etc, but NOT for
Toyota. So, whoever you got this radio from must have had it in a
different car and 'lost' the original connector!
This is NOT good! It looks like 15-16 pins? The Toyota connector has 10
pins on one connector, and 5 on the other.
The only thing is, if the wires are EIA standard (Purple, green, white,
grey, red and yellow) then you can take the info I've given you and get
some push pins at an electronics store, crimp or solder them on and mate
them to yuour car's connector.
I'll take another look on Scosche's web site, they may have further info...
G
Discussion Starter · #7 ·
There was a significant change - the car went through a major redesign
in 1992.
Use the 92-96 manuals.
See:
http://www.turboninjas.com/camry/
Electrical wiring diagrams section.
G
Discussion Starter · #8 ·
It is recommended you do not cut any original Toyota wires.
Ask crutchfield.com to send the correct wiring harness connector and
color codes for your model year.
Then you do all the splicing and soldering (or wire nuts) on wires that
are not part of the original wiring in the car.
1 - 9 of 9 Posts
