1 - 4 of 4 Posts
B
Guest
Re: Full Time 12V Power Outlet rewire for '04 Corolla
On Wed, 31 Jan 2007 00:18:01 GMT, "jane doe" <[email protected]> wrote:
>Can somone please provide information on what to rewire or jumper or
>whatever needs to be modified to have the 12V auxiliary power points
>(cigarette lighter jacks) have power when the ignition key is either off or
>out of the ignition. The car is a 2004 toyota corolla.
Easiest and safest way is to add an auxiliary power socket and leave
the factory lighter socket power supply alone, since it has a thermal
protector in it that you can easily trip by running power accessories
for long periods. Plus, having the lighter socket power switched is a
safety measure to keep from lighting the car on fore - it's fairly
easy to drop a parcel or item and push in the lighter element to where
it won't pop out and shut itself off.
Add an auxiliary power outlet under the dashboard. If you only need
5 amps or so, tap off the dome light fuse (or another constant
circuit) at the fusebox - they have "Add-a-Circuit" taps that plug
into the fuse holder prongs and give you a second lead.
How much power do you need for these accessories, and for how long?
(So I can come up with an average amp-hour draw.)
You can't use a lot of power (I'd stop at 5 Amp-hours) with the
engine turned off without deep-cycling and ruining the regular
starting battery - they do NOT like that usage, they are made to give
a big burst starting the engine and then be immediately recharged.
--<< Bruce >>--
J
Guest
Discussion Starter #2
Bruce L. Bergman <[email protected]> wrote in message
news:[email protected]
or
> --<< Bruce >>--
No lighter element came with the car, just the cigarette jack and a plastic
cover. The label inside the cover sais "don't exceed 50W". 50w/12v= 4.1Amps.
I'm way under that.
So I'm not worried about fire or anything dropping in it.
I only plan to use a GPS unit. 300ma. I prefer using the cigarette power
jack. Perhaps I can jumper it to the "Add-a-Circuit" tap. I don't know where
the cigarette power jack wire ends up; in the fuse box or somewhere else ?
R
Guest
"jane doe" <[email protected]> wrote in message
> or
>> --<< Bruce >>--
> plastic
> 4.1Amps.
> I'm way under that.
> where
The cigarette power jack wire ends up at the lighter fuse.
Ray O
J
Guest
Thanks all.
> On Wed, 31 Jan 2007 21:49:00 -0600, "Ray O"
> >> plastic cover. The label inside the cover sais "don't exceed 50W".
> >> 50w/12v = 4.1 Amps. I'm way under that.
> But you can see how wedging the lighter element in can cause it to
> get way hot, right? When you do the dodge below, hide the element so
> someone can't play with it...
power
> >> where the cigarette power jack wire ends up; in the fuse box or
> >> somewhere else?
> But after that (feeding the fuse) it goes through the accessory
> relay in one of the fuse blocks, probably the one under the hood.
> You can use an Add-A-Fuse tap and wire one in reverse - Tap off a
> constant fuse (like the Dome light) to get the always on lead, then
> connect a .110 male tab crimp connector to mimic a fuse prong and plug
> it into the "out" side of the Lighter fuse to feed constant power to
> the lighter. Easily reversible when you sell the car.
> If that makes no sense, print this out and go find a radio installer
> or a mechanic - they'll go "Oh, Yeah!" and fix you up fast.
> --<< Bruce >>--
1 - 4 of 4 Posts
