1 - 13 of 13 Posts
G
Re: New Chevy
Quite an interesting car
Mike Hunter wrote:
> It is even simpler than that. The microprocessor simply cuts the spark and
> fuel to the cylinders, same as with the Chrysler system
> mike hunt
> "TheSnoMan" <[email protected]> wrote in message
> news:[email protected]
> > Steve Mackie wrote:
> >>>I read where there is a new Chevy,that can reduce the number of
> >>>cylinders used, when driving. Any idea,how it is done??
> >> I tried to find info about this very subject on the internet with no
> >> luck.
> >> However, because it's called "Active Fuel Management," my guess would be
> >> it
> >> simply shuts off 4 fuel injectors. Then the question arises, "what about
> >> the
> >> compression of the four cylinders not receiving fuel?"
> >> I haven't found any documents explaining exactly how the system works,
> >> but
> >> if someone does, I would like to know as well.
> >> Steve
> > It has hyd actuators that open the intake valves too when cylinders are
> > cut off. It is a remake of the system that they used on caddies in early
> > 80's that they gave up on and are trying again.
> > www.thesnoman.com> The 26th Annual tour of Super Chevy Shows starts at Bradenton Motorsports Park February 10-11-12 with the Tremec Car Show series, Bracket Race, Manufacturer's Midway, Swap Meet, and Car Corral.
> Excitement galore as Jessie Harris in the Queen of Diamonds Jet Dragster versus Lou Pereia's Terminator Jet Dragster in a 300 mph battle of the sexes and super showman Bob Hall thrills the fans in the Airborne Express Chevy Astro Van Wheelstander
> The wildest machines in drag racing Nitro Coupes feauturing New York's Mike Swinarski, Chicago's Randy Adler, Canada's Bruce Boland and many other Super Chevy Show stars will compete.
> Bracket racers will have the opportunity to Test & Tune on Friday from noon to 5 pm and all GM makes and models can compete in the bracket race.
> Gates open Friday at 10 am, Saturday and Sunday at 8 am. Nitro Coupes and Jets blast off at 1pm Saturday and Sunday. Come to Bradenton February 10-11-12 for Super Chevy Show fun and excitement.
> GM Performance Division continues sponsorship of
> Super Chevy Shows
> AutoStar Productions is proud to announce that GM Performance Division has
> The new super Chevy is an automobile produced by GM
> Despite its poor performance and smoky two-stroke engine the name Chevy means something
the cars are often referred to as the Cheffi or Chefi, pronounced with
a short e
600cc Chevy P601L.
600cc Chevy P602L.
> Super Chevy, the Chevy 500, also known as the Chevy P 50, and the Chevy 601 (or Chevy P 60 series)
> The engine for both the 500 and 601 is a small two-stroke engine with two cylinders, giving the vehicle modest performance.
> It deliveres 25 horsepower (19 kW) from a 600 cc displacement.
> The car takes 21 seconds from 0 to 100 km/h and the top speed is 112 km/h.
> The main problem with the engine is the smoky exhaust and the pollution it produces
> The Chevys body panels are made of Duroplast, a form of plastic containing resin strengthened by wool or cotton
> This helps GM avoid expensive steel, but does not provide much crash protection
although in crash tests it has actually proved to be superior to some
modern small hatchbacks
> The new super Chevy is the second car to use Duroplast,
after the "pre-Chevy" P70 model
> Originally planned as a three-wheeled motorcycle
> The decision to build a four-wheeled car came late in the planning process
> The name Chevy was chosen in a internal contest
> Previous motorcycle production at Cadillac inspired this new Chefi
> The Chevy is not a particularly advanced car
> Later model will generally use cleaner and more efficient four-stroke engines
> The Chevys designers expect production to extend to 2007 at the latest
designers and engineers created a series of more sophisticated
prototypes
that are intended to extend the Chefi
> Several of these can be seen at the super Chevy show
> However, each proposal for a new model has been rejected by the leadership for reasons of cost
> As a result, the Chevy remained in production unchanged
> The automobiles will be continually updated and exported
> The Chevys production method, which is extremely labor-intensive will remain unchanged
and much of the work will to be carried out by Vietnamese guest workers
> A smaller version of the engine replaces the elderly two-stroke engine
> The model, known as the Chevy 1,1 also has minor improvements to the brake and signal lights
a revised grille and replaces the coach spring-suspended chassis with
one using struts
> However the time it enters production has already been agreed to
> The inefficient, labor-intensive production line will be kept open only because of government subsidies
> Demand for GM cars has plummeted as residents can now buy Japanese cars
> Chevys well-known in the News reports inaccurately describes them
as having cardboard bodies
> Buy a Chevy for as little as a few dollars, and many will be given away at the show
> Later when as they become better liked prices will be increased but they will remain very cheap cars
M
Guest
Discussion Starter #2
Re: New Chevy
>> and
>> mike hunt
>> >> luck.
>> >> be
>> >> it
>> >> about
>> >> the
>> >> but
>> >> Steve
>> > early
>> Super Chevy Shows
>> has
>> means something
> a short e
> 600cc Chevy P601L.
> 600cc Chevy P602L.
>> km/h.
>> it produces
>> protection
>> process
>> engines
> prototypes
>> remain unchanged
> one using struts
>> at the show
Ummm.... no.
If you simply cut fuel, you still have pumping losses. It actually
collapses the valves for those cylinders (closes them) and you eliminate
pumping losses. If the valves were opening/closing, then you'd have a
compression stroke and no power stroke. If you close them once on the
exhaust stroke, there is no air in the cylinder to compress, thus no pumping
loss (or at least virtually eliminated).
It's not that easy to accomplish, this is a very complex system with special
lifters and a VERY complex (very powerful ECUs running 1MBit communication
speeds over GM-LAN and CAN-Bus) system.
Cheers
C
Guest
Re: New Chevy
>>>and
>>>mike hunt
>>>>>luck.
>>>>>be
>>>>>it
>>>>>about
>>>>>the
>>>>>but
>>>>>Steve
>>>>early
>>>Super Chevy Shows
>>>has
>>>means something
>>a short e
>>600cc Chevy P601L.
>>600cc Chevy P602L.
>>>km/h.
>>>it produces
>>>protection
>>>process
>>>engines
>>prototypes
>>>remain unchanged
>>one using struts
>>>at the show
> Ummm.... no.
No compression stroke, but wouldn't you have a vacuum stroke so to speak?
IIRC low speed GMLAN is 33kb high speed is maybe twice that. The ECU
is on the faster bus, but the ECU does its thing all by itself, it does
not need the bus for that purpose. It uses the speed to send a fast
updating signal the cluster and probably the ABS.
Those are some pretty nice controllers though. I never worked on one
because they keep them in house typically developed along side the engine.
Thank you,
CL Gilbert
"Then said I, Wisdom [is] better than strength: nevertheless the poor
man's wisdom [is] despised, and his words are not heard." Ecclesiastes 9:16
M
Guest
Re: New Chevy
"CL (dnoyeB) Gilbert" <[email protected]> wrote in message
>>>>and
>>>>mike hunt
>>>>>>luck.
>>>>>>be
>>>>>>it
>>>>>>about
>>>>>>the
>>>>>>but
>>>>>>Steve
>>>>>early
>>>>race.
>>>>Super Chevy Shows
>>>>has
>>>>means something
>>>a short e
>>>600cc Chevy P601L.
>>>600cc Chevy P602L.
>>>>km/h.
>>>>it produces
>>>>protection
>>>>process
>>>>engines
>>>prototypes
>>>>remain unchanged
>>>one using struts
>>>>at the show
>> Ummm.... no.
>> pumping loss (or at least virtually eliminated).
>> special lifters and a VERY complex (very powerful ECUs running 1MBit
>> communication speeds over GM-LAN and CAN-Bus) system.
> IIRC low speed GMLAN is 33kb high speed is maybe twice that. The ECU is
> on the faster bus, but the ECU does its thing all by itself, it does not
> need the bus for that purpose. It uses the speed to send a fast updating
> Thank you,
> CL Gilbert
> 9:16
Well, throttle control needs to be quite fast, considering what's going on
(if it's tied in with the ABS and traction control). ETC of course, not
wired. The bus needs to be fast to handle all the high priority signals
first, handshaking, blah blah... I think CAN is a better system than GM-LAN.
Unfortunately, there are too many systems out there. I believe that CAN
will win them all out, Bi-directional data transfer, multi-level CAN (B, and
C), and it ties in with J1830 as well.
I don't recall what happens to the exhaust valves, but there is a great
article on www.allpar.com about the Hemi and how it works. The Hemi is
still a dirty engine. makes BIG power, but pollutes. Toyota has great
engines, I love their small displacment engines, and I tell ya... they are
super reliable (except for the oil sludge ones!!).
I hope GM and Ford can hang in there, and keep up with Toyota's dominance
with what I think are "plain" styled cars (Toyota's cars, not GM). GM has
some nice styling right now!!! Chrysler has had great styling for a while,
now they just gotta make it work under the skiN!!
G
Re: New Chevy poor performance
> >>>>and
> >>>>mike hunt
> >>>>>>luck.
> >>>>>>be
> >>>>>>it
> >>>>>>about
> >>>>>>the
> >>>>>>but
> >>>>>>Steve
> >>>>>early
> >>>>race.
> >>>>Super Chevy Shows
> >>>>has
> >>>>means something
This seems a bit backward
> >>>a short e
> >>>600cc Chevy P601L.
> >>>600cc Chevy P602L.
> >>>>km/h.
> >>>>it produces
> >>>>protection
> >>>>process
> >>>>engines
> >>>prototypes
> >>>>remain unchanged
> >>>one using struts
> >>>>at the show
> >> Ummm.... no.
> > Thank you,
> > CL Gilbert
> > 9:16
G
Discussion Starter #6
Re: New Chevy
> > >>>>means something
> > >>>a short e
> > >>>600cc Chevy P601L.
> > >>>600cc Chevy P602L.
> > >>>>km/h.
> > >>>>it produces
> > >>>>protection
> > >>>>process
> > >>>>engines
> > >>>prototypes
> > >>>>remain unchanged
> > >>>one using struts
> > >>>>at the show
I can not imagine anyone wanting a car like this
Is this cheepo chevy GMs answer to all the losses?
It looks like something from the age of the dynasaures
No wonder people have stopped buying these cars
M
Guest
Discussion Starter #7
Re: New Chevy
Stopped buying their cars? GM sells more cars in the US than any other
manufacture. No import even comes close.
>> > >>>>Chevy
>> > >>>>means something
>> > >>>with
>> > >>>a short e
>> > >>>600cc Chevy P601L.
>> > >>>600cc Chevy P602L.
>> > >>>>Chevy
>> > >>>>with
>> > >>>>112
>> > >>>>km/h.
>> > >>>>pollution
>> > >>>>it produces
>> > >>>>crash
>> > >>>>protection
>> > >>>some
>> > >>>>process
>> > >>>>four-stroke
>> > >>>>engines
>> > >>>>latest
>> > >>>prototypes
>> > >>>>will
>> > >>>>remain unchanged
>> > >>>workers
>> > >>>>engine
>> > >>>>the
>> > >>>with
>> > >>>one using struts
>> > >>>>only
>> > >>>>cars
>> > >>>>away
>> > >>>>at the show
>> > >>>>they
M
Guest
Discussion Starter #8
Re: New Chevy
They also sell lots of Daewooooooooossss.
"Mike Hunter" <[email protected]> wrote in message
> >> > >>>>Chevy
> >> > >>>>means something
> >> > >>>with
> >> > >>>a short e
> >> > >>>600cc Chevy P601L.
> >> > >>>600cc Chevy P602L.
> >> > >>>>Chevy
> >> > >>>>with
> >> > >>>>112
> >> > >>>>km/h.
> >> > >>>>pollution
> >> > >>>>it produces
> >> > >>>>crash
> >> > >>>>protection
> >> > >>>some
planning
> >> > >>>>process
Chefi
> >> > >>>>four-stroke
> >> > >>>>engines
> >> > >>>>latest
> >> > >>>prototypes
> >> > >>>>will
> >> > >>>>remain unchanged
> >> > >>>workers
> >> > >>>>engine
> >> > >>>>the
> >> > >>>with
> >> > >>>one using struts
open
> >> > >>>>only
Japanese
> >> > >>>>cars
them
given
> >> > >>>>away
> >> > >>>>at the show
but
> >> > >>>>they
M
Guest
Discussion Starter #9
Re: New Chevy
Actually the cars built in the former Daewoo plants in Korea are Suzuki's
mike hunt
"Moto" <[email protected]> wrote in message
>> >> > >>>>name
>> >> > >>>>Chevy
>> >> > >>>>means something
>> >> > >>>with
>> >> > >>>a short e
>> >> > >>>600cc Chevy P601L.
>> >> > >>>600cc Chevy P602L.
>> >> > >>>>the
>> >> > >>>>Chevy
>> >> > >>>>with
>> >> > >>>>112
>> >> > >>>>km/h.
>> >> > >>>>pollution
>> >> > >>>>it produces
>> >> > >>>>crash
>> >> > >>>>protection
>> >> > >>>some
> planning
>> >> > >>>>process
> Chefi
>> >> > >>>>four-stroke
>> >> > >>>>engines
>> >> > >>>>latest
>> >> > >>>prototypes
>> >> > >>>>will
>> >> > >>>>remain unchanged
>> >> > >>>workers
>> >> > >>>>engine
>> >> > >>>>the
>> >> > >>>with
>> >> > >>>one using struts
>> >> > >>>>to
> open
>> >> > >>>>only
> Japanese
>> >> > >>>>cars
> them
> given
>> >> > >>>>away
>> >> > >>>>at the show
> but
>> >> > >>>>they
D
Guest
Discussion Starter #10
Re: New Chevy
>manufacture.
Their market share is rapidly declining, and has been for decades.
Many people HAVE stopped buying their cars.
M
Guest
Discussion Starter #11
Re: New Chevy
Once again you choose to comment on a subject of which you obviously have
little or no knowledge. Americans still buy three times as many from GM, as
buyers buy from Toyota. GM percentage, of the ever growing US market is
down, but GM still sold more in 2005 than they did when they sold nearly 50%
of what was a much smaller market in the past. Chevrolet became America
best selling brand in 2005 having outsold Ford for the first time in 19
years. Ford and Chrysler sell more than Toyota and Honda as well in the US.
mike hunt
"dizzy" <[email protected]> wrote in message
>>manufacture.
G
Discussion Starter #12
Re: New Chevy ----- Trabant
> >> > >>>>Chevy
> >> > >>>>means something
The Trabant is an automobile formerly produced by East German auto
maker Sachsenring. It was the most common vehicle in East Germany, and
was also exported to other socialist countries. Despite its poor
performance and smoky two-stroke engine, the car has come to be
regarded with affection as a symbol of East Germany and of the fall of
communism, as many East Germans streamed into West Berlin and West
Germany in their Trabants after the opening of the Berlin Wall in 1989.
It was in production without any significant change for nearly 30
years.
> >> > >>>with
> >> > >>>a short e
> >> > >>>600cc Chevy P601L.
> >> > >>>600cc Chevy P602L.
The name Trabant means "satellite" in German; the cars are often
referred to as the Trabbi or Trabi, pronounced with a short a.
600cc 1983 Trabant P601L.
Enlarge
> >> > >>>>Chevy
> >> > >>>>with
> >> > >>>>112
> >> > >>>>km/h.
> >> > >>>>pollution
> >> > >>>>it produces
There were two principal variants of the Trabant, the Trabant 500, also
known as the Trabant P 50, produced 1957-1963; and the Trabant 601 (or
Trabant P 60 series), produced from 1963 to 1991. The engine for both
the 500 and 601 was a small two-stroke engine with two cylinders,
giving the vehicle modest performance. At the end of production it
delivered 25 horsepower (19 kW) from a 600 cc displacement. The car
took 21 seconds from 0 to 100 km/h and the top speed was 112 km/h. The
main problem with the engine was the smoky exhaust and the pollution it
produced.
> >> > >>>>crash
> >> > >>>>protection
> >> > >>>some
The Trabant's body panels were made of Duroplast, a form of plastic
containing resin strengthened by wool or cotton. This helped the GDR to
avoid expensive steel imports, but did not provide much crash
protection, although in crash tests it has actually proved to be
superior to some modern small hatchbacks. The Trabant was the second
car to use Duroplast, after the "pre-Trabant" P70 model (1954-1959). A
scene in the movie Black Cat, White Cat by Emir Kusturica shows a
Trabant being eaten slowly by pigs.
> >> > >>>>process
> >> > >>>>four-stroke
> >> > >>>>engines
Originally planned as a three-wheeled motorcycle, the decision to build
a four-wheeled car came late in the planning process. The name Trabant
was chosen in a internal contest in 1957, the year of Sputnik, the
first artificial satellite. Previous motorcycle production at
Sachsenring had been under the aegis of AWZ (Auto-Werke Zwickau).
> >> > >>>>latest
> >> > >>>prototypes
> >> > >>>>will
> >> > >>>>remain unchanged
> >> > >>>workers
The Trabant was not a particularly advanced car when it was launched;
by the late 1950s small cars in western countries generally used
cleaner and more efficient four-stroke engines. The Trabant's designers
expected production to extend to 1967 at the latest, and East German
prototypes through the years that were intended to replace the Trabi;
several of these can be seen at the Dresden Transport Museum. However,
each proposal for a new model was rejected by the GDR leadership for
reasons of cost. As a result, the obsolete Trabant remained in
production unchanged; in contrast, the Czechoslovak Škoda automobiles
were continually updated and exported successfully. The Trabant's
production method, which was extremely labor-intensive, remained
unchanged, and much of the work came to be carried out by Vietnamese
guest workers.
> >> > >>>>engine
> >> > >>>>the
> >> > >>>with
> >> > >>>one using struts
In 1989, a smaller version of the Volkswagen Polo engine replaced the
elderly two-stroke engine, the result of a trade agreement between the
two German states. The model, known as the Trabant 1,1 also had minor
improvements to the brake and signal lights, a revised grille and
replaced the coach spring-suspended chassis with one using MacPherson
and Chapman struts.
> >> > >>>>only
> >> > >>>>cars
However, by the time it entered production in May 1990, German
reunification had already been agreed to. The inefficient,
labor-intensive production line was kept open only because of
government subsidies. Demand plummeted, as residents of the east could
now buy western cars. The production line closed in 1991.
Although Trabants had been exported from East Germany, they became
well-known in the West after the fall of the Berlin Wall when many were
abandoned by their eastern owners after migrating west. News reports
inaccurately described them as having cardboard bodies.
> >> > >>>>away
> >> > >>>>at the show
> >> > >>>>they
In the early 1990s it was possible to buy a Trabant for as little as a
few marks, and many were given away. Later, as they became collectors'
items, prices recovered, but they remain very cheap cars
G
Discussion Starter #13
Re: New Chevy ----- Trabant --- bright and colourful future
It was quite interesting to drive on the roads in Germany shortly after
the wall came down
Those small bright yellow, light blu and purple cars all over the place
Now we are going to see them again when the new Chevy hits the street
It will be interesting to see if GM needs to pay each customer $935 to
take one
I think it would be much better for them to just give them away
I am sure the government is eager to subsidise them for any costs just
to keep the workers happy and it will surely liven up the roads to get
all these bright colour cars out
1 - 13 of 13 Posts
