Re: Re: 95 Corolla heater vent
558 Views 1 Reply 0 Participants Last post by  =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
G
It looks like it is the heat control slider itself that is out of
wack. If I move it around a bunch it seems to "sometimes " fix it.
I have an other question, how do you remove the dash cover that goes
over the radio and heater ? do you just pull it off ? I cant seem to
find any screws. I also want to get to the stereo to replace it.
Thanks for your reply Mike
"Hachiroku_$B%O%A%m%/(B" wrote:
> On Sat, 23 Dec 2006 18:25:33 +0000, bettinamike wrote:
> > I have just purchased a 1995 Corolla, all works fine except
> the heater.
> > The heater air is either cold or hot, nothing in between.
> It seems like
> > the air mixture valve or flap or whatever controls the
> mixture is not
> > working. any suggestions ? Need help.... Its cold
> This is interesting. Now, when you say cold or hot, is it by
> chance? I
> mean, one time you start the car and get cold air, and the
> next time hot,
> or do you mean moving the lever makes the air either cold or
> hot?
> If you look on the firewall, where the hoses enter the
> firewall for the
> heater core, you should see a valve on the intake hose. There
> should be a
> cable connected to it (this is assuming this system is NOT
> controlled by
> vacuum...), have someone move the lever from cold to hot and
> back. If,
> while moving the lever it stays all the way to one side, and
> then all of a
> sudden jumps to the other side, then the cable is probably
> binding
> somewhere. This is pretty intensive, you'll have to take a LOT
> of the dash
> out to figure out there it's binding (unless you're a LOT
> luckier that I!)
> If it's controlled by vacuum, then the best I can tell you is
> look for a
> cut or pinched or blocked hose somewhere...
> Good Luck!
Posted at author's request, using http://www.AutoBoardz.com interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: http://www.AutoBoardz.com/95-heater-vent-ftopict201303.html
1 - 2 of 2 Posts
G
On Mon, 01 Jan 2007 07:25:12 +0000, bettinamike wrote:
> It looks like it is the heat control slider itself that is out of wack. If
> I have an other question, how do you remove the dash cover that goes over
> the radio and heater ? do you just pull it off ? I cant seem to find any
Look Here (With a tip of the hat to Ray O.):
http://www.pro-fit-intl.com/Adobe/TY-52-97.pdf
> > the heater.
> > It seems like
> > mixture is not
> > This is interesting. Now, when you say cold or hot, is it by chance? I
> > mean, one time you start the car and get cold air, and the next time
> > hot,
> > or do you mean moving the lever makes the air either cold or hot?
> > If you look on the firewall, where the hoses enter the firewall for the
> > heater core, you should see a valve on the intake hose. There should be
> > a
> > cable connected to it (this is assuming this system is NOT controlled
> > by
> > vacuum...), have someone move the lever from cold to hot and back. If,
> > while moving the lever it stays all the way to one side, and then all
> > of a
> > sudden jumps to the other side, then the cable is probably binding
> > somewhere. This is pretty intensive, you'll have to take a LOT of the
> > dash
> > out to figure out there it's binding (unless you're a LOT luckier that
> > I!)
> > If it's controlled by vacuum, then the best I can tell you is look for
> > a
> > Good Luck!
1 - 2 of 2 Posts
