Re: Replacing engine (2C with 4A-FE)
I use to have a Toyota Carina Diesel Engine (2C) from Japan and 3 weeks ago I replaced the Engine with a 4A-FE Engine. I had to replace the wiring except the inside ones.
The first problem i have encountered is that i noticed that the cooling fan is not coming on even if the engine is overheated, all the sensors are connected and tested the fan and it works, but does not work once on the car.
second problem is the idle speed is to high and i dont know how to bring it down.
third, the display on the dashboard has gone crazy nothing response as they should
Could someone please help me
