1 - 20 of 22 Posts
I recently bought a 2009 Highlander 4WD V6 and was browsing through the Toyota maintance schedule that came with it. I found it refreshingly simple compared to my wife's Honda and most of the other vehicles I have owned. But why the frequent retorque of these bolts(I guess they mean bolts although it says bolt). I can't recall any of my other cars or trucks (4WD or 2WD) requiring this.
Ken
2007 Camry XLE
It's in the 2009 Highlander maintainence
Thanks for replying. Toyota apparently added this for 2009. When I looked at the link you provided which was for the 2008 model, the re-torque bolt item wasn't there. When I changed the year to 2009, there it was. Maybe they have had reports of problems. And it is in the booklet that came with it.
Those bolts are located in the stern, and require 250 ft/lb of torque. Its the shaft that holds your propeller on. HA! Its the bols around the drive shaft where they meet the universal joint. Dont know the torque specs.
It's in the maintenance section of my 2008 Hybrid...so not just 2009. In addition, the hybrids do not have a driveshaft to the rear wheels...?!
I wonder if those of us that own a 2008 model should be doing this as well.
2012 Highlander
Propeller shaft bolts
Hello everyone
I have noticed in my 2012 Highlander service recommendations that starting at 16000km (10000 miles) and every 16000km after, the "propeller shaft bolts" need to be tightened (with a $25 charge). Is anyone familiar with this service? Do these bolts constantly loosen over time and cannot be permanently tightened like the rest of the bolts on the car? What do these bolts do and is this a safety concern? Is this a Toyota recomended service or a dealer added service/cost?
Thanks
***merged with pre-existing thread on topic, sweeneyp***
Resident Nutcase
'08 Highlander Limtd
Well that's interesting, it must be a new 2011+ HL service requirement. My 08 service manual does not mention the shaft bolts, but the one for the 2011-2012 does for the 4WD HL (but it says only if you tow or are on dirt roads often.) Most dealers I've been to automatically check those options for any service. Before I used my HL for towing (before it even had a hitch) I saw them check the box that I tow with my highlander...I don't understand dealers :lol:
Anyway summing it up, it listed that re-torquing is required every 15k miles, but if used for towing or used on dirt roads, its listed every 5k miles.
2018 HL Limited
Sweeney, I'm glad you defined this procedure as for "4WD". I assume this procedure refers to the prop shaft driving the rear differential. I was wondering how in heck I would even find the 2WD prop shaft bolts under all that confusion up front. :eek:
Resident Nutcase
And FWIW, here's a past thread that talks about re-torquing those bolts.
well shoot, I didn't even know that thread existed, it was "before my time" :lol: I'll merge them, thanks.
edit: hytec,
yep this is for the prop shaft heading to the rear diff. The front setup is a bit different, there aren't really any bolts directly on the front drive shafts to re-torque down, they are just kinda held "in place" by other components. But your right, working/finding anything in the front is a pain :lol:
2008 Highlander Base
Sometimes it scares me that I remember these old threads....:facepalm:
:lol:
Hope the OP can find it useful....
Was a 05 Tacoma 4x4 DC LB
I do wonder why they need to be re-torqued. We have this same requirement on the Tacoma every 15K miles IIRC, and yet I've never heard of one being loose. Then there's the debate on procedure. Do you simply check that they don't need to be tightened more, or do you break them loose and re-torque them? FWIW, I do the former. And I quit checking them so often since they've never come loose.
Since I haven't been underneath the HL yet (will be in the not too distant future for the rear diff and TC fluid changes), do the u-joints have zerks or are they sealed? (Toyota uses both on the Tacoma: 4wd has zerks, 2wd has no zerks)
Resident Nutcase
going to go with sealed. I saw nothing related to zerks or having to use grease on the install, inspection, or reassembly of the prop shafts.
54 ftlbs where it connects to the rear diff and where the 2 prop shafts connect in the center.
sweeneyp,
haven't looked under my Highlander, but does it need to be torqued where it meets the transfer case? If its anything like my old Rav, there were 4 bolts at the diff, 4 at the tsfr case, and 2 in the center.
1 - 20 of 22 Posts
