1 - 3 of 3 Posts
R
Guest
Re: Toyota Corolla transmission fluid change interval ??
"Larry" <[email protected]> wrote in message
news:[email protected]
>I have an 2005 Corolla with Automatic.
> Took it to Jiffy Lube, they wanted to change the tranny fluid. My car
> has 37000 miles on it. The owners manual says 60K if towing, and never
> if not using as a tow vehicle. Checked with the dealer and they said
> every 15,000! and don't exceed 30K.
> So what is the straight information. 15K sounds like they are trying
> to make money off of me. I have an explorer with 240,000 on it with the
> original automatic in it. I change the fluid every 50K and have had no
> problems.
> ...Larry
You should not have any problems if you follow the factory maintenance
schedule. If you want to be on the safe side, change the automatic
transmission fluid (ATF) every 30,000 or 60,000 miles. Your transmission
may require special ATF that Jiffy Lube does not carry so check for the
correct ATF in your owner's manual before letting Jiffy Lube have a go at
it.
Ray O
L
Guest
Discussion Starter #2
In article <[email protected]>,
"Ray O" <rokigawaATtristarassociatesDOTcom> says...
> > problems.
> > ...Larry
> it.
It does use Toyota T-IV or Valvoline type 33-03 so I will have the
dealer do it.
....Larry
I wouldn't let Jiffy Lube touch my Toyota. I have heard to many horror storys about them.I have 42,000 miles on my 2016 Toyota Corolla and i will take it to my dealer to have the transmission fluid changed at 60,000. I plan on keeping my car as long as possible. I take care of it and i don't let just anyone work on it.
1 - 3 of 3 Posts
