Here is a sticky with links to the various DIY projects we have going here. They’re specified as being to the respective area they are a part of. Best of luck with your DIYs! Thank you to all the creators of these DIYs...it is because of you that these are a possibility! And remember, we assume no responsibility for your mistakes. Enjoy!
It would be a good idea for any person doing DIY work to purchase a Haynes or Chilton manual that will answer most any repair question. If you have something you think should be added to this sticky, or if you see something that is in error, please send a PM with the link/information to any of the Corolla section Moderators. Thank you, and please check back occasionally for updates. -- TrailDust
Remember nearly all of this stuff applies universally to 2003-2008 Matrix and Pontiac Vibe and to some extent the 2000-2005 Celica and MR-2/MR-S -- HardtopTE72
The following is a list of all the DIYs available for 9th gen Corollas. If you come up with a new one, please PM a Corolla section Moderator or Admin and they will add it to the list. Thanks!
If you have any questions regarding maintenance, please READ THE FOLLOWING THREAD FIRST!:
Brakes, Steering, and Suspension:
Brake System Flush with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Front Brake Job with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Front Sway Bar End Link Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
How To Replace Brake Lines(2003-2008 Corolla, Matrix, Pontiac Vibe)
Painting Front Brake Calipers (2003-2008 Corolla, Matrix, Vibe)
Power Steering Fluid Exchange with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
www.toyotanation.com
Rear Drum Brakes - Cleaning and Adjustment with Pics! (2003-2008 Corolla, Matrix, Vibe)
Rear Drum Brakes - Disc Brake Conversion with Pics! (2003-2008 FWD Corolla, Matrix, Vibe)
Rear Drum Brakes - Hub and Bearing Assembly Replacement with Pics! (2003-2008 FWD Corolla, Matrix, Vibe)
Engine:
CAI: How To Make Your Own
Charcoal Canister Replacement with pics! (2005-2008 Corolla, Matrix, Pontiac Vibe)
Cooling Fan Always On: A Fix (2003-2008 Corolla, Matrix, Pontiac Vibe)
Coolant Flush with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Downstream Oxygen Sensor Replacement with Pics! (2003-2008 Corolla)
Drive Belt Tensioner and Drive Belt Replacement with Pics! - 1ZZFE (2003-2008 Corolla, Matrix, Pontiac Vibe)
Drive By Wire Throttle Body Cleaning with Pics! - 1ZZFE (2005-2008 Corolla, Matrix, Pontiac Vibe)
Engine Cover Plastic Retainers Replacement (2003-2008 Corolla, Matrix, Pontiac Vibe)
Engine Swap Tips - 1ZZFE (2003-2008 Corolla, Matrix, Pontiac Vibe)
EVAP System Diagnosis (2003-2004 Corolla, Matrix, Pontiac Vibe)
Injector Flush using OEM kit with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Intake Gasket Replacement with Pics! - 1ZZFE (2003-2008 Corolla, Matrix, Pontiac Vibe)
MAF Sensor Cleaning with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Oil Change (2003-2008 Corolla, Matrix, Pontiac Vibe)
Oil Pan Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
P0171 Clogged Injector Diagnosis (2003-2008 Corolla, Matrix, Pontiac Vibe)
Passenger Side Engine Mount Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
PCV Valve Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Port and Polish - 1ZZ-FE
Replacement: Throttle Body and Intake Manifold Gaskets and Removal and Cleaning: Throttle Body and IACV with Pics! (2003-2004 Corolla, Matrix, Pontiac Vibe)
Spark Plug Replacement with Pics! (2005-2006 Corolla XRS, 2003-2006 Matrix XRS, 2003-2006 Pontiac Vibe GT)
Serpentine Belt Routing Diagram:
Starter Replacement with Pics! - 1ZZFE (2003-2008 Corolla, Matrix, and Pontiac Vibe)
Thermostat Replacement with Pics! - 1ZZFE (2003-2008 Corolla, Matrix, and Pontiac Vibe)
Timing Chain Tensioner or Timing Chain Tensioner O-Ring Replacement with Pics! - 1ZZFE (2003-2008 Corolla, Matrix, and Pontiac Vibe)
Turn Signal Mod with Ram Air Intake DIY included
Upstream Air Fuel Ratio or Oxygen Sensor Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Vacuum Switching Valve at the Charcoal Canister: How to test/diagnose this VSV for P0446 trouble code (photo & video)
Valve Cover Gasket Replacement with Pics! - 1ZZFE (2003-2008 Corolla, Matrix, Pontiac Vibe)
Passenger side Engine Mount DIY w/ Pics
Exhaust:
Donut Gasket Between Exhaust Manifold and Exhaust Pipe (with video)
Resonator Replacement and Exhaust Flange at Muffler Fix (with video).
Transmission:
4 Speed A245E/A246E Automatic Transmission, Front Pump Seal, Rear Main Seal, and Axle Seal Replacement with Pics! (2003-2008 Corolla, Matrix, and Pontiac Vibe)
4 Speed A245E/A246E Automatic Transmission Fluid Exchange & Strainer Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
5 Speed C59 Clutch and Rear Main Seal Replacement with Pics! (2003-2008 Corolla, Matrix, and Pontiac Vibe)
5 Speed C59 Manual Transmission Service with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
5 Speed C59 Manual Transmission Rear Bearing Replacement with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
6 Speed C60 Manual Transmission Service with Pics! (2005-2006 Corolla XRS, 2003-2006 Matrix XRS, 2003-2006 Pontiac Vibe GT)
Broken Auto Transmission Shifter/Shift Select Cable Repair with Pics! (2003-2008 Corolla)
Fix 1 Gear Shift Doesn't Actually Change Gears. Linkage Problem? Automatic.
Fix 2
Clutch Fork/Slave Cylinder Noise Fix with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Short Shifter Install with Pics! (2003-2008 Corolla)
Transmission mount DIY
Interior:
A/C Filter Change with Pics! (2003-2008 Corolla, Matrix, Pontiac Vibe)
Auto Dimming Mirror Install (2003-2008 Matrix and Pontiac Vibe - Others may be similar)
Auto-dimming mirror upgrade (w/ compass!) – ElectroLund
Blanking Clock Repair (2003-2008 Corolla)
Finally! A fix for those damn blanking clocks! - Fix 1
How to fix your clock on your 2003-2008 Toyota Corolla - Fix 2
Center Storage Console Repair with Pics! (2003-2008 Corolla)
Console Light Replacement (2003-2008 Corolla)
Cruise Control Install (2005-2008 Corolla, Matrix, Pontiac Vibe)
DIY: Aftermarket cruise control install - Auto
Added Cruise Control - Manual
Front Door Panel, Window Glass, and Window Regulator Removal with Pics! (2003-2008 Corolla)
Front Window Run and Door Glass Replacement with Pics! (2003-2008 Corolla)
Gauge Cluster/Odomoter Maxed out at 299,999 Miles/KM Discussion (2003-2008 Corolla, Matrix and Pontiac Vibe)
Gauge Cluster Replacement with Pics! (2003-2008 Corolla)
Rear Speaker: How To Remove Them
How To Remove Rear Speakers from a 2007 Toyota Corolla S
Steering Wheel, Airbag, AirBag Cover, and Airbag Cover Badge Replacement (2003-2008 Corolla, Matrix and Pontiac Vibe)
Matrix power window retrofit
Transmission Shifter Light Bulb Replacement
DIY Heated seat
Exterior:
Alloy Wheels: How to Patch Up Scratched Wheels
BMWTips wheel-scuff repair
Fog Light Install of eBay-style OEM lights
Front Bumper Cover and Headlights: Removal and Replacement
Front Door Check Replacement (2003-2008 Corolla, Matrix and Pontiac Vibe)
Headlight (Low Beam) Bulb Change
Hella Horns Install (2003-2008 Corolla, Matrix and Pontiac Vibe)
Morimoto Mini H1 HID Projector Retrofit Guide
Rust Repair and Paintwork - Basic Tips
Sunroof Seal Replacement (2003-2008 Matrix and Pontiac Vibe - Others may be similar
General:
Auto-Light and DRL: The Ultimate Thread
Tire Rotation
Miscellaneous:
Cold Engine Noise
Common Problems and What to Look For During Purchase
General Matrix Info
Wheel Fitment Thread
DIY: 2003-2008 Corolla, Matrix, and Pontiac Vibe Power...
I completed this procedure at 78,000 km on my 2008 Corolla. Toyota does not officially recommend a replacement interval on the power steering fluid, however mine was getting a bit dirty looking, so I decided to change it. Disclaimer Use this guide at your own risk! I assume no responsibility...
DIY 2003-2008 Corolla, Matrix, Vibe Rear Brakes Clean...
Hello I did this a while ago so here is the actual DIY. This procedure is almost universal to drum brake Toyotas. The only difference in Camry and a few other models is they are adjusted from in front of the drum. Disclaimer: Myself or Toyotanation are not responsible for any damage or...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe Rear Drum to...
Hello everyone. I decided I would make a DIY on the rear disc brake conversion I did for my 2005 Corolla. This DIY will apply identically to all 2003-2008 FWD Corolla, Matrix, and Pontiac Vibe models with rear drum brakes. It will be very similar for 2000-2005 Celica GT models with drum brakes...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe FWD Rear...
Hello everyone. I had a replacement bearing go bad on my 2003 Corolla LE and decided I would make a DIY for replacement. This DIY will apply to all 2003-2008 FWD Corolla, Matrix, and Pontiac Vibe models with rear drum brakes. It will be very similar for 2ZZGE equipped 2003-2006 Matrix XRS and...
Engine:
Fixed: Radiator Fan Constantly Running - A/C Pressure...
Hello everyone. As I mentioned in a few posts I had an issue with my 2003 Corolla where the radiator fan was always running with key on. Not only was the radiator fan always running, but it was running on high speed (these cars have one fan that runs at 2 speeds; low and high). I searched...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe Drive Belt...
Hello everyone, while forum member ksteve45 was getting his transmission done, I decided to snap a pic of the drive belt tensioner replacement I also did. This DIY will apply to all 2003-2008 Corolla, Matrix, and Pontiac Vibe models with the 1ZZFE engine. It will be very similar for 2ZZGE...
DIY 2005-2008 Corolla, Matrix, Pontiac Vibe DBW Throttle...
Ok the much needed DIY for DBW Throttle body cleaning. I have used this method for hundreds of Toyotas and my own several times. Never had an issue. This is similiar for all Toyotas that use DBW with the differences being the removal of the air hose, etc. This is by far the easiest throttle to...
HardtopTE72 1ZZFE Swap Tips Thread - Everything You...
Hello everyone! Since I have made a couple of these tip posts in response to posters with varying levels of information contained within, I decided to put all the relevant information for these swaps in one place. These tips should apply to all 2000-2008 VVT-i 1ZZFE engines for Corolla...
2004 Corolla EVAP Diagnostic Guide
For those of you struggling with resolving EVAP DTCs, I've put together the attached guide which was based on my (drawn-out) experience finding the problem on my 2004 Corolla S. I hope it might help some of you!
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe Intake...
Well I am up here in Virginia for a little while and it's been pretty cold. The past few days my idle has been very low and I knew my original intake gasket had run its course (104k is alright with me). So I headed over to Priority Toyota and spent around 7 bucks and change to get an updated...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe MAF Sensor...
This is something quick I made up. It is really easy to do. This applies directly to 2003-2008 Corolla, Matrix, and Pontiac Vibe and similarly to all Toyotas that use the 2 bolt MAF Sensor from basically the 1990's to Present. Disclaimer: Myself or Toyotanation are not liable for any damage or...
Yet another mysterious lean engine (P0171) code
Hi all - this is my first post and I was hoping to get some thoughts on my troubleshooting process (and I apologize for my long post, but I want to make sure I give as complete a picture as possible). A little over a year ago, my 2003 Corolla LE (136,000 miles at the time) check engine light...
DIY: Motor Mount Passenger Side Replacement with photos
How To Replace The Passenger Side Engine Mount: Tools: 14mm deep socket longer and standard sized 3/8" ratchet medium and long 3/8" extentions 10mm socket Floor jack with a block of wood Stretch cord or rope/twine Torque wrench suitable for 38 ft. lbs. Jack stands and wheel chocks Flashlight...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe PCV valve...
I know this is an easy one but just in case I made a DIY for PCV valve replacement. This DIY was done on a 1ZZFE, but will apply identically to all 1ZZFE or 2ZZGE cars including Celica, Corolla, Matrix, Pontiac Vibe, and MR2/MR-S. I used the OEM PCV valve since its cheap enough and its a...
DIY 2003-2004 Corolla, Matrix, Vibe TB, IACV, and Intake...
Other DIY's exist for these tasks, but this guide explains how to replace all three gaskets and clean everything at the same time - which you might as well do if you're going to invest the time to do any one of these tasks. This guide is very detailed: it discusses cleaning and replacing the...
For anybody who needs it, here is a diagram showing the routing for the serpentine belt: Here below is a sequence that forum super moderator hardtopte72 recommends for installing this belt: "Install the drive belt. Place the belt into the installation position. I like the install the belt...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe Starter...
Hello everyone. After 13 years and 181K miles, the OEM starter in my 2003 Corolla decided to call it quits. After considering the price and reviews, I went with a TYC replacement starter from Amazon. I think total spent was around $100. This DIY was performed on my 2003 Corolla LE Automatic...
DIY 2003-2008 Corolla, Matrix, and Pontiac Vibe 1ZZFE...
Hello everyone. As part of my proactive maintenance regimen, I decided to replace the thermostat on all my vehicles. This DIY was performed on my 2005 Corolla CE. This DIY will apply identically to 2003-2008 Corolla, Matrix, and Pontiac Vibe models. It will also be very similar for 1998-2002...
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe 1ZZFE Timing...
I finally got around to doing a timing chain tensioner DIY for the 1ZZFE thanks to a leak on my 2003 Corolla LE. The leak depicted is after cleaning it about a month ago. This DIY will apply universally to all 1999-2008 Corolla, Matrix, Chevrolet Prizm, and Pontiac Vibe and should be very...
Exhaust:
Transmission:
DIY 2003-2008 Corolla, Matrix, Pontiac Vibe A245E/A246E...
Hello everyone! Forum member kzsteve45 was having some issues we decided was best repaired by a transmission replacement, so I jumped on the opportunity to make a DIY. In addition to replacing the transmission, we replaced the rear main seal, front pump seal, filter and gasket, transmission pan...
DIY 2003-2008 Corolla, Matrix, Vibe Transmission Fluid...
I completed this procedure at 49,000 km on my 2008 Corolla 1.8L automatic (with the 1ZZ-FE engine). The transmission fluid was getting a bit dark looking on the dipstick. To the best of my knowledge, the transmission fluid was the original fluid that was supplied with the car. [EDIT June 1...
Fix 2
DIY: Motor mount replacement - Left Hand (Driver's...
DIY: How to replace the Left Hand (Driver’s side) motor mount (actually it’s a transmission mount). This is for the Automatic transmission. This DIY is meant for those who need step-by-step instructions with photos. Toyota Nation has all kinds of members: Pros, Advanced DIYs, Mid-Level DIYs...
Interior:
DIY 2003-2008 Corolla Front Window Run and Door Glass...
Hello everyone after reviewing the previous threads on window run replacement, I decided to make a DIY for the replacement I did on my 2003 Corolla. This procedure differs pretty significantly from the TSB repair and you may or may not like the way I do this. I got my window runs from Roman at...
Toyota Nation Forum
retrofit power windows
hi all.i went to the scrap yard today and pulled out the power window regulators and switches. i also cut the harnesses inside the doors. I have an 08 matrix base model with power locks but no power windows. has anyone tried doing the retrofit? i went on youtube and found where the relay should...
DIY Heated seat
DIY Heated seats installation on '05 Corolla S?
Write up on how to add heated seats to your 9th gen Corolla: Prior to doing any of this, disconnect the negative terminal of the battery and tape the terminal. You need to make sure that the terminal and battery post DO NOT make contact since you will be touching airbag connectors. Seats...
Exterior:
D.I.Y. OEM Type Fogs
as promised, my fogs came in today and here is the detailed writeup for anyone that would need it... also suggestions would be appreciated... 1.) make sure that you have everything you need... (lights, wire harness, switch, and relay) 2.) remove the black plastic covers currently in the...
General:
Ultimate DRL and Autolight Thread
Well I am in the planning stages of an HID retrofit and one of my biggest issues is the DRL running with the low beam causing failure of the HID ballasts. So after a few hours of research and a ton of dead ends I think I have the definitive thread to answer all questions related to the DRL...
Tire Rotation
Miscellaneous:
Cold Engine Noise
General Matrix Info
