1 - 4 of 4 Posts
Mad Scientist
94 scepter coupe
Discussion Starter #1 (Edited by Moderator)
ENGINE, TRANSMISSION, & EMISSIONS:
Changing spark plugs the easy way
5 speed swap
CAI build
Changing the PCV valve and grommet
Block heater installation
Knock sensor replacement
Knock sensor replacement, part II
1MZ-FE engine tear down thread on Solaraguy.com
Differential fluid change
Transaxle output shaft (aka: CV shaft & half shaft) seal replacement
Replacing starter solenoid contacts
Fixing a P1705 - Direct clutch speed sensor replacement
Fixing a P0500 - Vehicle speed sensor replacement
AUDIO SYSTEMS:
Very helpful threads on stereo installation on amplified avalons.
Also speaker upgrades without ruining your interior.:thumbsup:
Double DIN Android installation
Stereo install help thread
Put 5.25 componets in my 98 XLS (PICS!!!!)
95 radio install step by step
Front door adaptors to fit 4 3/4" or 5 1/2" round speakers
Crutchfield 1995-1996 Toyota Avalon with 6 or 7 Speakers Wiring Information
How to remove the woofer grill on a 7 speaker system
ELECTRICAL & LIGHTING
Installing 130 amp alternator from a Highlander
Aftermarket alarm dash LED integration
Headlamp compatibility within the Gen1
OEM fog light installation
Replacing the bulbs on the instrument clusters and HVAC controls
Installing LEDs in the climate controls
Fixing the cigarette lighter socket
SUSPENSION & BRAKES:
Rust belt rear sway bar
Front brakes DIY
Brake upgrade options, from the Gen 3/4 Camry forum
STEERING:
DIY: GEN1, Rack & Pinion replacement, with pics
MISCELLANEOUS:
Replacing rear power window regulator
Center console removal
Floor shifter disassembly
Fixing the "A" pillar wind noise
Fix for water in doors making a sloshing noise
Wheels from other vehicles that will fit
How to debadge your Avalon
Fuel fill door spring
Cleaning the remote FOB contacts
Adding a replacement remote (FOB)
Windshield washer spray nozzle upgrade
PERFORMANCE MODS:
Solara strut tower brace installation
BMR's edit: If you know of any other Gen1 Avalon DIY threads that should be listed here, please PM me or another moderator/admin with a link to it. Also, if you're inclined to make one that doesn't already exist, please do!
Toyota has a kit to update/repair the harness and connector at the knock sensors on the 1MZ. This assembly is a beefed up version of the one that shipped on the vehicle. Currently I am a lube tech at a Toyota dealer, and stumbled into this while fixing a car my fiance bought. A master tech (20+ years exp) next to me warned me to replace them when I had access to them, but parts would take a day and I didn't want to extend my time on the car, so I was really careful with them instead. Nope, if you disturb or even have access to these wires at all during a job, and they are the originals, the general rule at our dealership is to offer to replace them. A slight breeze across their fragile copper bones is often enough generate knock sensor codes, after the fact, I just found this to be true; believe me, I was very gentle on these wires! Replace them if you touch them at all. Now I have to take the intake off again, and I will be crossing my fingers that 1) the new intake gaskets don't need to be replaced 2) Two Gallons of 'Toyota Red Coolant' don't spill or become contaminated 3) The knock sensors may be broken (not likely) which would have known by just doing this in the first place! And most importantly, I'll be finishing this at my house because 4) Embarrassment of not taking good advise from a respected mentor technician should he find out!
For our California Emission, 1999 Avalon XL, with the 1MZ-FE engine, The part number is "82219-07010", Description: "Wire, SE121" and list is $37.95. CHANGE TO THIS PART IF YOU HAVE ACCESS TO IT ON YOUR 1MZ-FE ENGINE! :eek:wnedsmas
Super Moderator
A master tech (20+ years exp) next to me warned me to replace them when I had access to them...
Excellent advice. I just replaced knock sensors and that cable on my Camry, and the cable connectors at the knock sensors crumbled like egg shells when I tried to disconnect them. I guess ~20 years of heat & fumes took its toll.
1 - 4 of 4 Posts
