after my 87 22r sits overnight, it gets to be a real pain to start. it needs to crank for about 5 whole seconds before it'll sputter a little. once it starts to sputter if i turn the key and hit the gas just right it'll roars to life and runs fine. when the engine is a little warm it starts up no problem also. it's got 200k without a rebuild as far as i know and the last time i checked compression it was at about 150 on all cylinders. is that low enough to cause this rough starting or is it more likely linked to something else?
also FYI i just did an amateur head gasket replacement a couple weeks ago. while it seems like everything went fine with it since the truck runs better now, this starting problem did pop up since then so maybe i caused it?
