Did you get the e-brake unstuck? If not, you could always undo the two bolts that attach the e-brake bellcrank to the backing plate. This will allow the e-brake to release and may free up the drums. Catch here is that you will then have to fix the e-brake issues before you can put it all back together again. If Tacomas are anything like the older trucks, it usually requires the disassembly of the bellcrank and cleaning out the rust, lubing it up and reassembling.
