Trying to replace brake pads on a 2009 Matrix. The rear brakes are discs, the type where the e-brake is part of the caliper
Initally I tried to push back the caliper pistons with a C-clamp - was applying a lot of force and couldn't get it to move at all! After a bit of research I realized that my pistons are the 'push and turn' type - so now trying to figure out how to do this - lots of conflicting information online, so figured I'd ask the forum!
- Q1: to push to pistons IN, do I turn clockwise or counter-clockwise?? One website said it's different between driver-side and passenger-side - why would they do that? Sounds like it's clockwise for both rear brakes?
- Q2: do I need to open the bleed port before I push the pistons back?
- Q3: tried to twist piston with needle-nose pliers, but the piston is very hard to grip (sloped 'cross' style pattern on the piston). Sounds like I need a special tool? People keep referencing this little 'cube' tool that attaches to a 3/8 ratchet that has different sides to fit different styles of turn-pistons - will this thing work for the Matrix?
So far finding this brake job rather frustrating! Hoping the good people here can help!
Thanks in advance!!
