At 150600 miles I still have the original drum and shoes. Last oil change/tire rotation I pulled off the drums to inspect the brakes. The shoes still had about 2.5 mm left on them, did not have proper calipers to check drum for spec. There was lots of dust as you would expect after all this time. I cleaned out the dust with brake parts cleaner and reinstalled everything.
Now when I apply the breaks [mostly first thing in the morning] I can hear a high pitched groan from the left side rear break.
Is it possible that I need to lube the parts where the shoes touch the backing plate?
With life still left on the shoes, does it makes sense to keep the existing shoes or should I get new ones?
At this age and mileage does it make sense to get all new hardware (springs etc) or just disassemble and reuse existing springs?
I have worked on disk brakes before, never on drum brakes. Thanks in advance for any guidance
99 Camry I4 150500 miles
