Hello,
I am overhauling the rear suspension of a 99' Camry LE 2.2L w/ ABS and removed everything minus the trailing arms because the 10" Bolt wont come off Rear Knuckle...
A. To my understanding these bolts only have threads at the end and not throughout the body because if so the rubber bushings would deteriorate at an alarming pace ?
B. if that's the case why wont this bolt come off ?
the following is what I tried thus far:
D. Should it slide out easily if it was new model ?
E. Is there a recommend method/tool to extract the bolt ?
F. Also can you please provide detailed steps with pictures and/or videos for this problem ?
G. Last question, does the knuckle have a hollow tube that bolt runs through or is the body of the bolt just exposed by design ?
I've attached are photos of the Knuckle and Bolt.
Thank you guys so much !
- Hitting it with a hammer from the tail end (going to buy another 10" bolt anyway)
- Putting the torch to knuckle and entry/exit ways of the Bolt
- Spraying it with WD-40 and another strong chemical spray and let it soak overnight
