1 - 7 of 7 Posts
Hi,
I was wondering if someone has a part number for the following 2 arms located in the rear suspension: Front lateral arm, Rear lateral arm. #2 amd #6 in the attached image.
http://img26.imageshack.us/img26/7796/8513645.gif
Also, do you know if bushings can be purchased separately?
my 99 solara v6 also has a bad bushing on rear control arm #2, the symptom is the rear wheel has excessive left to right swing. i went to dealer, and they only sell the whole piece for $125, i didn't try pepboy or autozone, cus a lot of time they will just said it is a dealer part.
probably cheaper to try junkyard.
Well, all 4 of mines are bent. Junkyard is a good option, but I doubt those bushings will be fresh, so if I can't get just bushings to install in the junkyard's arms might as well but 4 new arms, I found them $95 for adjustable and $85 for the other one.
Discussion Starter #7
I don't think so. I have seen this website already and there aren't any listed for 97-01, if you look under 92-96 - read note in red.
Does anyone one know which models are interchangeable?
1 - 7 of 7 Posts
