1 - 3 of 3 Posts
My wife's 2006 Highlander Hybrid Limited has under 126,000 miles and now we are having a issue with the rear passenger window.
The window will roll up and down from the rear passenger seat/switch perfectly fine. We can roll it down from the drivers master control switch only as it will not roll up from the master switch.
I went ahead and took the master switch off and cleaned the circuit board with electrical cleaner and rubbing alcohol. After reassembling the switch it's still only rolling down and not up for the rear passenger side window however all the other windows will go up and down just fine.
I've attached some photos.
If you don't slow down in life to take in what's around you before you know it you'll blink and miss your whole life.
-Warren L. Shafor
1 - 3 of 3 Posts
