1 - 2 of 2 Posts
1995 Toyota Tercel
Hey guys,
My rear defroster doesn't seem to work. When I switch it on the light comes on, but it does not defrost the rear windshield. I looked at all the fuses, checked that both sides of the connectors are connected to the copper lines, and I even checked to see if there is a cut between all the lines on the glass that may be cutting the circuit, but all seems fine. What do you guys think?
95 Tercel DX 5 speed
Sounds like you don't have power going to the rear defrost. Check for voltage on the wires that connect to the rear window. If there isn't any voltage, then I would check the back of the defrost switch to see if the wires are connected well there-maybe they got pulled out.
______________________________________________________________________
1995 Toyota Tercel DX 5-SPD, Cold Air Intake, KYB GR-2, coil-over springs
1 - 2 of 2 Posts
