Went to O’reilly’s to pick up a (Trico) 55-100
To flip up the wiper, since you can’t. Take a
pry tool, and pry the cap towards the passenger side of the car, then you can flip up
Push down on the right side of the pivot on the wiper blade to rotate the blade out along the pivot
note arm
the arm matches the picture for that is used for adapter “A”. Install adapter
install into arm, and push firmly so that it locks into the arm
remove protective sleeving, lay wiper on rear window, rotate cap and slide into arm
note arm
