1 - 9 of 9 Posts
I've got a 1989 4wd short bed 22re. The rear end has a slight whine underway but a really loud whine while coasting in gear. It goes away in neutral or clutch in. Is there anything that can be put in the rear end to quiet it down or is this strictly a mechanical fix. Thanks for any feedback.
· Supafly
1991 toyota pickup
You can try checking the torque of the main pinion nut, it might have loosened off. Chances are once there is significant noise, the damage is done.
Also try draining the fluid and look for excess metal shavings
You can try wood shavings, would work for a few miles at least :D
Hard to say, but if your gonna continue to drive it you should re torque the pinion nut and drain and refill the gear oil.
· NY born, Texas raised
Mine will do the same thing if I let off the gas at highway speed. When I lube the drive shaft the sound goes away. I also do the u-joints while I am there. I must do it every 2 months or I get the whine. Been doing it for 5 years and nothing has fallen off yet.
Just a suggestion since a grease gun and tube of grease is cheap.
· Supafly
1991 toyota pickup
Thats no good. You got driveline issues my friend!:thumbsdow
Yeah but it has been like that since I got the truck and hasn't gotten any worse. I just keep'em lube. If it finally falls off some day, that will be the day it gets fixed.
1 - 9 of 9 Posts
